b18c5 compression issue, feels weak
Old Sep 11, 2008 | 05:35 PM
swtch7's Avatar
Default b18c5 compression issue, feels weak
Im looking into trading a motor and some parts for a b18c5 longblock. The motor is still in the car so I was able to run a compression check
190
190
200
220
Cylinder 4's valve cover gastket was messed up so some oil dripped down into that cylinder and none of the others. Which could explain the higher number. My question is, should this be a concern and are the numbers to low? Under heavy acceleration I did see some black smoke out of the exhaust. I did drive the car and the motor felt weak, he had hondata s100 so im not sure if it was a crappy tune or the motor is just weak.
If I ended up getting the longblock, how much would it run to get the cylinders honed and new ringlands put in? Looking to pick this up this weekend if I get it, any info would be greatly appreciated. thanks
Old Sep 11, 2008 | 05:57 PM
John M's Avatar
Default Re: b18c5 compression issue, feels weak (swtch7)
i live in the 757 also
whos car is the motor coming out of?
and hat is kinda low cause my itr was 260
Old Sep 11, 2008 | 09:03 PM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swtch7 &raquo;</TD></TR><TR><TD CLASS="quote">Im looking into trading a motor and some parts for a b18c5 longblock. The motor is still in the car so I was able to run a compression check
190
190
200
220
</TD></TR></TABLE>This statement is not truth. Oil can not drip down into the cylinder with a bad valve cover gasket. The first two number are too low suggesting a blow-by maybe. Better do a leak-down test.
Old Sep 11, 2008 | 10:10 PM
tartje's Avatar
Default Re: b18c5 compression issue, feels weak (CW-ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">This statement is not truth. Oil can not drip down into the cylinder with a bad valve cover gasket. The first two number are too low suggesting a blow-by maybe. Better do a leak-down test.</TD></TR></TABLE>
if oil has leaked past the gasket and filled up where the plug sits, then you take the plug out it's going to then all run into the cylinder
Old Sep 11, 2008 | 10:14 PM
swtch7's Avatar
Default Re: b18c5 compression issue, feels weak (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">if oil has leaked past the gasket and filled up where the plug sits, then you take the plug out it's going to then all run into the cylinder </TD></TR></TABLE>
exactly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">i live in the 757 also
and hat is kinda low cause my itr was 260</TD></TR></TABLE>
some guy out in denbeigh. Drives a black ls with jdm frontend.
mostly looking to find out how much it will run to get a shop to hone and place rings?
Old Sep 11, 2008 | 10:41 PM
John M's Avatar
toms motor?
black ls with the jdm front and white optional sides and rear and front lip?
thats my boy if so that car is stout as hell
im actuley taking it out this weekend he is gonna let me drive it.
Old Sep 12, 2008 | 02:16 AM
swtch7's Avatar
Default Re: b18c5 compression issue, feels weak (John M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">toms motor?
im actuley taking it out this weekend he is gonna let me drive it.</TD></TR></TABLE>
yup, toms motor. Cool guy and all, and yes stout as hell car but the motor... not so much. You'll see what im talking about. If you have a leak down tester would you mind testing it please? thanks
Old Sep 12, 2008 | 08:21 AM
CW-ITR's Avatar
if oil has leaked past the gasket and filled up where the plug sits, then you take the plug out it's going to then all run into the cylinder </TD></TR></TABLE>Weel, yea, in that case, it'll happen. But, I don't think that's what the OP meant.
Old Sep 12, 2008 | 08:37 AM
swtch7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Weel, yea, in that case, it'll happen. But, I don't think that's what the OP meant.</TD></TR></TABLE>
its exactly what I meant. [QUOTE=swtch7]
Old Sep 12, 2008 | 08:45 AM
John M's Avatar
Yeah i love his car.
we always hook each other up.
i know the motor in his car is a usdm itr swap which is a b18c5
he told me it was untuned but ive saw him drive away getting on it and it sounded good but have yet to drive it .
Old Sep 12, 2008 | 09:13 AM
swtch7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i love his car.
he told me it was untuned but ive saw him drive away getting on it and it sounded good but have yet to drive it .</TD></TR></TABLE>
yea its a c5, but he said it has jdm internals. I think im going to go ahead and pick it up from him anyway. Ill just hone the block and put in new rings. Hopefully thats the only thing wrong with it.
Old Sep 12, 2008 | 09:34 AM
John M's Avatar
nice.
how much are you getting it for?
Old Sep 12, 2008 | 09:37 AM
swtch7's Avatar
a fair price I believe.
Old Sep 12, 2008 | 09:45 AM
John M's Avatar
Nice.
Ill be out at the meet tomm night
look for a nsx blue eg hatch on some hand polished spoon sw388's and carbon hood and lip and duckbill with red recaros.
Old Sep 12, 2008 | 09:49 AM
CW-ITR's Avatar
</TD></TR></TABLE>Sorry, in that case, do that to the rest of the cylinders and check the compression again. They probably all have about 200ish now. Now, turn on the engine and let it run to burn out all the oil that was collect in the four cylinders earlier. Now, with no more oil in the cylinder, if the compression drop back down to 100ish, your rings are bad. Good luck
Old Sep 12, 2008 | 09:53 AM
swtch7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, in that case, do that to the rest of the cylinders and check the compression again. They probably all have about 200ish now. Now, turn on the engine and let it run to burn out all the oil that was collect in the four cylinders earlier. Now, with no more oil in the cylinder, if the compression drop back down to 100ish, your rings are bad. Good luck</TD></TR></TABLE>
Thank you, I will give it a shot and hope for the best.
Old Sep 12, 2008 | 09:56 AM
Evil Ryu's Avatar
jdm internals on a usdm b18c5?
you mean, jdm pistons??
Old Sep 12, 2008 | 09:59 AM
swtch7's Avatar
Default Re: b18c5 compression issue, feels weak (Evil Ryu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Ryu &raquo;</TD></TR><TR><TD CLASS="quote">jdm internals on a usdm b18c5?
you mean, jdm pistons??</TD></TR></TABLE>
yea, thats what he says
Old Sep 12, 2008 | 01:14 PM
Evil Ryu's Avatar
yea, thats what he says</TD></TR></TABLE>
perhaps he is mistaken and there's still usdm itr pistons, explaining the lower compression numbers?
i'm just speculating.
Old Sep 12, 2008 | 02:58 PM
swtch7's Avatar
i'm just speculating.</TD></TR></TABLE>
could be, speculation is good at the moment. Until I can run more tests on it to find out for sure. thanks for the input though
kPRO dz
Sep 6, 2009 07:55 PM
JDM_EK_JOE
Oct 22, 2007 07:11 PM
efking1985
Jul 26, 2007 07:13 PM
Minglor
Jul 30, 2006 05:09 PM
sirguy01
Jul 6, 2006 09:03 PM
