Hesitation/stumble at constant speed
Old Sep 11, 2008 | 03:25 PM
91gsrcivic's Avatar
Default Hesitation/stumble at constant speed
When driving at a constant speed it just kinda boggs down. My RPMs don't change, no CEL, can't figure it out. I've changed all sensors, distributor, intake, TB, head gasket, timing belt, injectors, resistor box, fuel filter, fuel pump, the engine harness, and added MSD.
Modified by 91gsrcivic at 4:30 PM 9/11/2008
Old Sep 11, 2008 | 03:28 PM
85crx509's Avatar
Default Re: Hesitation/stumble at constant speed (91gsrcivic)
this to happens to me when in low rpms usually when taking off in first.
dont know how to fixthis though
Old Sep 11, 2008 | 04:56 PM
innes887's Avatar
check your tps. if you have a bad contact on the potentiometer it will make the car stumble. also check timing too
Old Sep 11, 2008 | 05:01 PM
jaminze's Avatar
Default Re: Hesitation/stumble at constant speed (85crx509)
I have this exact same problem and its driving me crazy. sometimes when i go over a bump it bogs down or jerk like its about to cut off
Old Sep 11, 2008 | 06:10 PM
91gsrcivic's Avatar
Default Re: (innes887)
Already did that even replaced the throttle body. Had a shop here look at it and paid them for three hours of diagnostic time and they couldn't even tell me anything.
Old Sep 11, 2008 | 09:27 PM
QuickStyle's Avatar
in some situations if the charcoal canister is removed, it can develop that kind of problem. is your charcoal canister intact?
Old Sep 13, 2008 | 09:41 AM
91gsrcivic's Avatar
Default Re: (QuickStyle)
Yes it is.
Old Sep 14, 2008 | 04:44 AM
QuickStyle's Avatar
not a guarantee but it might fix your problem if you put it back on
Old Sep 14, 2008 | 07:41 AM
91gsrcivic's Avatar
I meant yes it is on my car
Cln94EG1's Avatar
I was told its your low speed fuel cut. My car does this as well. I hear its something that really never stops you just get used to it
Old Sep 18, 2008 | 01:32 PM
91gsrcivic's Avatar
Default Re: (Cln94EG1)
Yeah, I don't know bout all that. Cause mine doesn't just do it at low speeds, sometimes it'll do it when I take off, sometimes driving 35-40 around town, or 60-80 down the hwy, hell it even does it every now and then at idle.
Old Sep 18, 2008 | 02:33 PM
sleepingciv's Avatar
Default Re: (91gsrcivic)
check all vac lines for cracks also check all fuel lines under the car for wet spots
Old Sep 18, 2008 | 02:46 PM
Black4thgenEF's Avatar
Default Re: (sleepingciv)
If you have your 2 O2 sensors wired backwards it wont throw a code and will have pretty similar symptoms to what you describe. This is probably the number one problem in first gen B16 swaps because the SI harness plugs into the WRONG O2 sensor.
Old Sep 20, 2008 | 04:43 AM
91gsrcivic's Avatar
Default Re: (Black4thgenEF)
Hows that its a 1 wire o2 sensor?
afnan
Jan 7, 2014 01:56 AM
Topsykrets
Nov 17, 2012 11:16 PM
smokey68321
Apr 18, 2010 05:20 PM
hostile1
Aug 1, 2008 06:57 PM
b18bEG
Nov 7, 2002 06:49 PM
