axle greese
Old Sep 11, 2008 | 11:13 AM
zccr-xsi's Avatar
Default axle greese
ok i just got under my car today and i noticed there grease all over the rear bracket and some one the exhaust.i cleaned everything off and check over the axle boot i didn't see any holes or slices in the boot so where in the hell would this grease be coming from?
Old Sep 11, 2008 | 11:48 AM
EF_monster's Avatar
Default Re: axle greese (zccr-xsi)
how are the boots on the steering rack? i just dont know how it would get on your exhaust and rear mount though.
Old Sep 11, 2008 | 12:42 PM
zccr-xsi's Avatar
Default Re: axle greese (EF_monster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_monster &raquo;</TD></TR><TR><TD CLASS="quote">how are the boots on the steering rack? i just dont know how it would get on your exhaust and rear mount though.</TD></TR></TABLE>
one side is ripped on the tie rack,but this looks like it being slung around likeits coming from the axle.ill wipe it and when i look again there it is.i think i need to pull the axle and really look at the inner hub im wondering if it has a hole somwhere?but iver turned it and didnt see or feel anything.
Old Sep 11, 2008 | 12:46 PM
zrickety's Avatar
it could be a transmission or engine oil leak...drops will get blown and pick up dirt while you're driving and it will land in the back looking like grease
Old Sep 11, 2008 | 04:12 PM
zccr-xsi's Avatar
Default Re: axle greese (zrickety)
NOOOOOO! its grease
Old Sep 11, 2008 | 04:20 PM
Tyson's Avatar
if you really cannot find a rip in the boot, it can still be leaking thru the boot clamp.
Old Sep 11, 2008 | 04:39 PM
zccr-xsi's Avatar
Default Re: axle greese (Tyson)
its funny u mention that i was thinking the same thing.maybe it was sling out though the clamp!!
Old Sep 12, 2008 | 04:45 PM
zrickety's Avatar
i doubt it. clean it off...maybe you just ran over someone else's grease
Old Sep 13, 2008 | 05:16 AM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety &raquo;</TD></TR><TR><TD CLASS="quote">i doubt it. clean it off...maybe you just ran over someone else's grease</TD></TR></TABLE>
lol its coming from the axle,i wiped it a few differant times first time i noticed it was about a month ago when doing an oil change.
hey tyson is there any way to take the axle off and tighten that clamp?ill also check over the boot and see if it does have a pin hole in it.
Old Sep 13, 2008 | 04:39 PM
Tyson's Avatar
you probably dont have to take the axle off to tighten the clamp or put a new clamp on. it would certainly help tho. up to you.
Old Sep 13, 2008 | 05:56 PM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">you probably dont have to take the axle off to tighten the clamp or put a new clamp on. it would certainly help tho. up to you.</TD></TR></TABLE>
thats prob. what ill end up doing cause theres nuttin wrong with the axle itself.ill replace the clamp and see what happens.
Old Sep 13, 2008 | 06:36 PM
tico's Avatar
ive had problems also with the clamp especially ones from like autozone or kragen. so what i do is add a sealent around the boot opening and shaft meet. no problems so far
star77
Jul 3, 2008 10:11 PM
UltimX
Suspension & Brakes
Nov 1, 2005 02:21 PM
astig* DC2
Sep 19, 2005 04:52 PM
madman604
Oct 8, 2003 03:52 PM
