Door Lock Problem with Viper 5900
Ok. After a complete reinstall on my system, I got the alarm installed stealthly the way I planned. I now have a new problem.
The door locks lock when I arm the system. When I disarm the system, the door locks unlock, then after a few seconds, lock then unlock. It locks and unlocks until I rearm the system.
Anyone have an idea on this one? =P
Thank you!
Thank you!
I bought it from a car alarm stereo place, they installed it. I uninstalled it and reinstalled it stealthly. It could be a poor ground. I did kinda ground it in a dookie spot >.>. so it wouldnt be related to my door lock wiring/trigger at all yes? I'll try regrounding it in a different spot tonight.
Thanks for the tip
Thanks for the tip
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Many things could come into play. you said it does it on the disarm, So a bad ignition source could cause it. Bad ground as F.C.M. said.
I used the same ignition tap that the car audio place used. As for the ground I just shoved it behind a bolt on the frame. I didnt wire brush it. I'm gonna try wire brushing it to get it to bare metal then try again. If not, any other ideas?
I'd like a collective boosts of ideas going here to get this diagnosed quickly.
Thanks everyone!
Thanks everyone!
Ok I got it to work. It actually was a bad ignition wire connection. The connection fell out. It was kinda strange too. Everytime I did anything that would involve my parking lights [brake, signal, etc] my doors would unlock! After a few seconds the alarm would go "OMGOSH THE CAR IS ON AND UNLOCKED -lock-" =P Quite amusing and annoying to hit the brake and unlock your car.
Thanks for your help guys!
condor22
Jan 23, 2019 09:16 AM
eg:R
Nov 8, 2011 08:36 PM
94
