clutch stuck
Old Sep 10, 2008 | 09:07 PM
hammergunner's Avatar
Default clutch stuck
my clutch wont engage to the flywheel after i put the tranny on
i swapped out for an ACT pressure plate and clutch disc
and when i pressed the clutch arm, it felt very easy to move and after lettiing it go
i'd turn the pully but the half shaft wont spin?
it was working perfectly when i put the tranny on and now wont work?
and the tranny is fine and in first gear.
and the motor is out of the car
Old Sep 11, 2008 | 11:34 AM
BLACKLIST138's Avatar
Default Re: clutch stuck (hammergunner)
I just ate a package of fruit snacks and farted. The fart smells like frito lays potato chips
i mean since we are sharing stories and all...
When you come back, please elaborate on what the hell you are getting at here.
Old Sep 11, 2008 | 03:54 PM
STFU if you can't help then dont post ****
Old Sep 11, 2008 | 03:56 PM
ONCE AGAIN
the clutch wont engage to the flywheel
can the release bearing be stuck and do i need an aftermarket one, im using the stock one thats in the tranny
Old Sep 11, 2008 | 08:06 PM
slomofo's Avatar
GDD Member
The question makes no sense.
The clutch won't engage to the flywheel? The clutch is touching the friggin flywheel, what kind of stupid question is that?
Old Sep 12, 2008 | 03:00 AM
Default Re: (slomofo)
do not send me another hater pm because you are a dunce and posted a dumbass question kid.
no one can help you because you clearly dont know what you are doing. Theres 20,000 sets of instructions on how to install a clutch that you bypassed and did not catch when you installed it incorrectly. Take it to a mechanic before you tear something else up.
Old Sep 12, 2008 | 03:47 PM
listen you numb nuts
the pressure plate is holding the clutch and it wont touch the flywheel.
im wondering WHY ITS STUCK
LEARN HOW A CLUTCH WORKS
Old Sep 13, 2008 | 01:00 PM
Default Re: (hammergunner)
dunce
p.s. i already know how a clutch works... mine works fine. yours is the junk **** that wont work cause you dont know what you are doing. lol
Old Sep 13, 2008 | 01:23 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: (BLACKLIST138)
Just to make it easier fr someone to answer this question we need to clarify what is wrong. If the clutch was engauged, it would mean that the pressure plate is clamping the disc to the flywheel and it will allow the engine to tranfer power to move the car. If it were disengauged, the diaphram would be pushed in and the presure plate would no longer be clamping the disc to the flywheel and the engine would not be able to transfer power to move the car.
I only say this because your description of the issue is confusing. So is your clutch engauged or disengauged? You can im me if you need to. I answer clutchtech questions every day.
Old Sep 13, 2008 | 03:51 PM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammergunner &raquo;</TD></TR><TR><TD CLASS="quote">listen you numb nuts
Take a picture because your description is not a very good one. If I try really hard to understand that horse **** you're writing, it kind of sounds like you put the clutch disc in backwards.
LEARN HOW A CLUTCH WORKS </TD></TR></TABLE>
Old Sep 13, 2008 | 03:58 PM
steven_highet's Avatar
Just shut the hell up!!!!!
The reason this site is here is to help people not to talk $hit like retarded ignorant people like you do. If you dont have any good info to put out shut the hell up!!!!!! NOT everyone is as "informed" as you!!
Modified by steven_highet at 5:03 PM 9/13/2008
EDWINV00SI
24
Oct 13, 2011 06:08 PM
m015094
Feb 19, 2007 11:44 AM
jabroni95gsr
Nov 4, 2001 06:04 PM
