New o2 and still throw code 41, need help asap, dyno is tomorrow.
Old Sep 10, 2008 | 04:21 PM
allmotorfreak's Avatar
Default New o2 and still throw code 41, need help asap, dyno is tomorrow.
I just get a new NGK o2 and the car still say code 41...i reset the ecu will the unpluged battery.
I try a another one...and still the same stupid problem...
My dyno guy said to me thats is maybe the heater in the O2 BUT i tried 2 different one so,im [freak]ed.
maybe the wiring but last week everything was perfect except the TPS that i change 2day.
PLEASE SOMEONE HELP ME!!! dyno is tomorrow and i really want to see my over 200whp this time.
BIG THANKS
Old Sep 10, 2008 | 04:28 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: New o2 and still throw code 41, need help asap, dyno is tomorrow. (allmotorfreak)
Check to see if the O2 heater wires have continuity.
Old Sep 10, 2008 | 04:36 PM
on the connector side ? and the plug in seem to be OK, nothing wrong there, the wire is perfect in the plug...well i will re-check in 30min
thx !
Old Sep 10, 2008 | 05:18 PM
2LEM1's Avatar
I like to party
Community Builder
Default Re: (allmotorfreak)
Isn't 41 "ineffeciant Catalyst"?
May not be the actual O2 sensor...
Old Sep 10, 2008 | 05:20 PM
mar778c's Avatar
Community Builder
Default Re: (2LEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't 41 "ineffeciant Catalyst"?
May not be the actual O2 sensor...</TD></TR></TABLE>
For OBD-1, that is primary oxygen heater.
https://honda-tech.com/zerothread/1901557
Old Sep 10, 2008 | 05:25 PM
2LEM1's Avatar
I like to party
Community Builder
Default Re: (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">
I'm so lazy...
Old Sep 10, 2008 | 05:27 PM
mar778c's Avatar
Community Builder
Default Re: (2LEM1)
I'm so lazy... </TD></TR></TABLE>
Lol
Old Sep 10, 2008 | 05:50 PM
so its just need to be warm up?
Old Sep 10, 2008 | 06:02 PM
N20civicB18's Avatar
Are you getting tuned or just doing a few pulls?
Old Sep 10, 2008 | 06:28 PM
full tuning, i dont really need the o2 for the tune because they use his o2 to tune it but for back home i want my car run with no check engine
Old Sep 10, 2008 | 06:32 PM
IntegraType-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorfreak &raquo;</TD></TR><TR><TD CLASS="quote">full tuning, i dont really need the o2 for the tune because they use his o2 to tune it but for back home i want my car run with no check engine
Relax, they can disable it, and u can run closed loop anyway, i do, have them tune partial throttle and u have no problems, you can disable all that nonsense.
Old Sep 10, 2008 | 06:39 PM
thx man, yeah i know, im all stress about that, i've been working on that setup like one month and i hate to have some lil prob at last time like that
Old Sep 11, 2008 | 01:14 PM
well the motor throw 204whp and 143wtq with a lot of trouble...i need to get back to OEM ignition, msd is not that good that i was thinking and i forget the put my timing cover back so the guys was not able to play with my timing and cam gear, they set to 0degres...well in 2week i go back there with a ready motor this time.
Old Sep 11, 2008 | 02:42 PM
Good numbers w/o dialing the gears in.. and ya, msd is fail.. oem ftw
Old Sep 11, 2008 | 05:08 PM
Fat Chick Magnet's Avatar
Samething happend to me. I replaced o2 sensor for no reason, but it turned out that the wire from the ecu harness fell out of the plug.. I'm assuming my friend had his foot all over the wire harness since my ecu is always throw on the floor and not tucked away.
Old Sep 11, 2008 | 07:29 PM
Default Re: (IntegraType-R)
pull on the 4 gear...the engine pull great, no traction in first gear in the street....but without the cam gear touched, the toda spec B feel like ctr cam lol, they set to 0degres :/ so in 1-2 week re-tune time.
Modified by allmotorfreak at 8:42 PM 9/11/2008
kcrxxx
Aug 13, 2007 05:10 PM
Ge-money
11
Mar 1, 2007 12:05 PM
spencedogg
12
Nov 30, 2003 11:57 AM
allmotorsi04
Nov 24, 2003 07:51 PM
fast[R]
Apr 24, 2002 04:58 PM
