no power to fuel pump
Old Sep 10, 2008 | 01:48 PM
elmalouno's Avatar
Default no power to fuel pump
Ok, so when i turn the key the pump does not prime.
i have checked the main relay, and it is in working condition
when i was going through the flow chart i jumped two points on the main relay harness and the fuel pump runs. so the pump is good.
the problem is that for what ever reason the pump is not being powered.
in the crx helm manual that i am looking at, page 6-80 "fuel supply system" , i am at step 7 and it has me test voltage at two points on the MFR harness. I do not get 12v when i turn the key like i should. the suggestion at this point is to check fuse #2(starter signal) or check the wiring between the ignition switch and the MFR.
the fuse #2 checks out fine, and from what i can tell the wiring is ok as well. there is no further instructions as to what the problem might be.
has anyone had a similar problem? i tried to go to my local yard today to see if i could pick up an ignition switch just to take shot in the dark, but they didn't have any.
any input will be appreciated.
Old Sep 10, 2008 | 01:50 PM
type Gendy's Avatar
Default Re: no power to fuel pump (elmalouno)
do you have 12v at the pump?
Old Sep 10, 2008 | 02:31 PM
elmalouno's Avatar
Default Re: no power to fuel pump (type Gendy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy &raquo;</TD></TR><TR><TD CLASS="quote">do you have 12v at the pump? </TD></TR></TABLE>
no only when i jump the MFR harness
Old Sep 10, 2008 | 03:24 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Fuse #14 labeled Alternator/solenoid provides power to the main relay:
Old Sep 10, 2008 | 03:52 PM
elmalouno's Avatar
Default Re: no power to fuel pump (88DXCRX)
just for ***** and giggles i replaced the chipped p06 with s300 hondata with a po5 stock ecu and the fuel pump primes fine. looks like i have a bad ecu.
Old Sep 10, 2008 | 06:15 PM
B16CRXT's Avatar
exactly what I was gonna suggest.
SpoonEk253
41
Oct 3, 2022 03:21 PM
EusebioSam19
Nov 22, 2010 09:21 PM
crazyimport
Sep 2, 2008 09:22 AM
frost_0ne
Sep 13, 2005 01:02 PM
jvans04
Jul 24, 2005 04:49 PM
