B16 harness and 02 questions
Quick questions, putting a b16 in my 92 VX.
If I use a harness off of a 92-95 civic si/ex it will plug into the 4 wire o2 sensor plug and into the VX chas. harness with no wire changes other than the wires I need to add?
Also the 4 wire o2's off of the 92-95 civic dx/si/ex will work with the b16 motor right?
Thanks for the help guys!
It's obd 1 going into a obd 1 car so there is no problem there.
Well I guess i'll just plug it all together and see what happens.
exactly what it says what websites are there? and what would i expect for a 99 si motor and tranny and OBDII to OBDI adapter? i asked in anothwr thread and no one aswered...
I currently run a b16a in my vx. Everything plugs up right. Since you had a wide band O2 sensor in the vx you'll have to figure out a way to re wire the four wire. I havent done it yet, but will very soon. I'll keep you posted. If you dont want your old VX O2 i'll be willing to buy it.
would be funny if ur car blows up...j/k....it should all plug rite in, no?
I think the main harness the engine harness plugs in is the same on the 92's. They all have vtec wires so i'm hoping by using the si/ex harness I won't have to rewire it for a 4 wire. If the vx has a different main harness then i'll have to do it anyway. Oh well, plug it in and see what happens...
lonely_driver4
Jan 18, 2019 09:54 PM
EARLdaSQUIRREL
Aug 20, 2003 08:13 PM
hughesl
Aug 7, 2003 05:11 PM
