B16 harness and 02 questions
Quick questions, putting a b16 in my 92 VX.
If I use a harness off of a 92-95 civic si/ex it will plug into the 4 wire o2 sensor plug and into the VX chas. harness with no wire changes other than the wires I need to add?
Also the 4 wire o2's off of the 92-95 civic dx/si/ex will work with the b16 motor right?
Thanks for the help guys!
Re: B16 harness and 02 questions (Briman2021)
i justa sed a similar question i think all you need is the OBDII to OBDI adapter for it or as i take the adivce i was given,,hope it helps
It's obd 1 going into a obd 1 car so there is no problem there.
Well I guess i'll just plug it all together and see what happens.
Re: B16 harness and 02 questions (nsxmatt)
exactly what it says what websites are there? and what would i expect for a 99 si motor and tranny and OBDII to OBDI adapter? i asked in anothwr thread and no one aswered...
I currently run a b16a in my vx. Everything plugs up right. Since you had a wide band O2 sensor in the vx you'll have to figure out a way to re wire the four wire. I havent done it yet, but will very soon. I'll keep you posted. If you dont want your old VX O2 i'll be willing to buy it.
would be funny if ur car blows up...j/k....it should all plug rite in, no?
Re: B16 harness and 02 questions (dniedacess)
I think the main harness the engine harness plugs in is the same on the 92's. They all have vtec wires so i'm hoping by using the si/ex harness I won't have to rewire it for a 4 wire. If the vx has a different main harness then i'll have to do it anyway. Oh well, plug it in and see what happens...
EARLdaSQUIRREL
08-20-2003 08:13 PM
hughesl
08-07-2003 05:11 PM
