Transmission & Drivetrain Gearboxes, Differentials, Clutches
ls 5th/reverse in a b16 tranny?
Old Sep 10, 2008 | 08:32 AM
boostedeg302's Avatar
Default ls 5th/reverse in a b16 tranny?
I have a quick question. I have a b16 non LSD tranny but 5th and reverse is bad. Will ls 5th gear and reverse fit? And if so would it be just the gears tht would fit or is the ls ring gear needed too? Any help is greatly appreciated
Old Sep 10, 2008 | 09:26 AM
Aquafina's Avatar
All you need for the 5th gear swap are the gears themselves. Can't change reverse, it is built into the mainshaft. Reverse ratio should be the same for all B series, but I never look at reverse ratios so don't quote me. Reverse is comprised of the mainshaft, 1/2 slider, and reverse idler gear.
Old Sep 10, 2008 | 09:44 AM
Default Re: (Aquafina)
ok great. The tranny won't go into reverse at all. Can I put the whole ls reverse set in it that you just mentioned
Old Sep 10, 2008 | 12:38 PM
IN VTEC's Avatar
Default Re: ls 5th/reverse in a b16 tranny? (boostedeg302)
To fix your problem, you need to replace the 5-R synchro set. Replacing just the gears won't solve the problem. You may need to replace the mainshaft 5th gear if the mesh teeth are mangled...in which case, you could justify replacing the B16 5th gears with LS 5th gears.
martymart92
21
Feb 10, 2010 12:42 PM
igorka_91
Nov 7, 2009 11:23 PM
BIG T
Aug 24, 2007 05:49 PM
96 GSR-T
Apr 9, 2006 12:25 PM
