Swapping gears in an LS Tranny?
Old Apr 6, 2006 | 06:43 AM
96 GSR-T's Avatar
Default Swapping gears in an LS Tranny?
I have an LS Tranny in my Boosted GSR, is it possible to install lets say a B16 5th gear to shorten the high end? How about a different final drive to make it rev faster? I did a search and did not come up with much......anybody ever experiment with these modifications??
Old Apr 6, 2006 | 08:19 AM
Blown90hatcH's Avatar
Default Re: Swapping gears in an LS Tranny? (96 GSR-T)
It is doable. Make sure when you swap 5th gears, you change both the counter and main shaft gears. Also the final drive, make sure you swap both the ring gear and the countershaft.
Jason
Old Apr 6, 2006 | 09:08 AM
Quad-Damage's Avatar
Default Re: Swapping gears in an LS Tranny? (Blown90hatcH)
here is what u should do
B16A2 Tranny, LS 5th gear and a LSD
that would be a pimp *** tranny, the quick gears from 1st till 4th and 5th gear long for freeway driving.
Old Apr 6, 2006 | 12:54 PM
96 GSR-T's Avatar
Default Re: Swapping gears in an LS Tranny? (Quad-Damage)
I would love to do something like that but I allready have the LS with a quaife, brand new ACT XTR6 and brand new Streelite Flywheel otherwise I would consider that.
Old Apr 9, 2006 | 12:25 PM
Bense's Avatar
b16 shift fork, b16 3rd gear, gsr 4th gear. and leave it at that. you have a quaife on your 4.2666 final drive. well instead of getting a b16 5th gear, get a 4.4 or a 4.785 final drive
bense, who's jealous of the nice readily available oem ratios that b-series can offer over d-series.
more info in the sig.
martymart92
Transmission & Drivetrain
21
Feb 10, 2010 12:42 PM
jchrm80
Sep 24, 2009 08:53 PM
boostedeg302
Sep 10, 2008 12:38 PM
fizic
10
Feb 23, 2004 08:03 AM
One8Hatch
Dec 18, 2001 09:08 PM
