b16 vs b18b which one better to boost after built bottom end?
Old Jul 25, 2002 | 08:18 AM
FDragger's Avatar
Default b16 vs b18b which one better to boost after built bottom end?
both of these are around 2300 bucks. they will both get sleeved (bigger) and receive lower compression pistons and stronger rods so stability is not a problem. im debating between the two right now. which would you choose and why?
Old Jul 25, 2002 | 08:33 AM
1337 Si's Avatar
Default Re: b16 vs b18b which one better to boost after built bottom end? (FDragger)
I plan on sticking with my b16, and were aiming for 400whp@16psi.
Old Jul 25, 2002 | 10:42 AM
AllMotorBrew's Avatar
it all depends on what top end you are going to be using becasue if you are going to be using a vtec head for the b18b then go with that it will have the lower end bower or the non vtec then the upper end power from the vtec and also be stonger than any b16a.
Old Jul 25, 2002 | 11:20 AM
2K_TEG's Avatar
Default Re: b16 vs b18b which one better to boost after built bottom end? (turbo924porsche)
I'd take the larger displacement. And forget the VTEC head, just build it up, and turn up the boost.
PphamEK
Jan 9, 2006 05:55 PM
PphamEK
Oct 15, 2005 08:26 PM
sqwale
Mar 30, 2005 05:26 PM
stierhund
Jun 27, 2003 06:49 AM
ej1civic
May 16, 2003 12:36 AM
