gsr power steering pump and ls power steering line.... vise versa... different sizes.
http://www.hondamarketplace.com/zerothread/2384088
I have a ls power steering line and a gsr pump.
The flanges/outlet size of the line and pumps are different. If i would get a ls pump, would there be anything wrong i might run into?
Why would they even be different?
I kinda would rather have the LS pump because i don't really want to re run the power steering line all the way down to the firewall. F that crap, it's a pain... Lol.
But yeah, would i run into any problems? Why are they different? Pros and Cons?
It's more about what year, rather than the engine.
The older pumps are larger and use a smaller nozzle on the high-pressure line. The pulley (with three holes in the face of the pulley) is also larger and underdrives the pump more than the newer ones.
The newer pumps are smaller and are overdriven with a smaller pulley (multiple holes in the pulley). I'll probably have to show you pictures to illustrate the differences so that you can decide what year of pump you need to be compatible with your PS high-pressure feed line.
The shaft seal and rear o-ring are different. The bearing looks the same though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">It's more about what year, rather than the engine.
The shaft seal and rear o-ring are different. The bearing looks the same though.</TD></TR></TABLE>
--- well i have a 1998 gsr. the power steering hose i had tro replace because it was cut.... so i put one on from a ls. it is smaller than the original.
so i have currently, a small hose.
so whatever year that came for i will need. or since i have the pump just the gsr power steering hose.
The one on the left is a '94 to '97 power steering pump. The one on the right is a '98 to '01 power steering pump.
Modified by IN VTEC at 6:07 AM 9/16/2008
Mfoehrkolb
Sep 10, 2008 06:22 AM
94CivicSi
Jul 31, 2008 08:34 AM
JussHatched
Apr 24, 2006 07:53 AM
