Power Steering Pullys
I recently swapped a b16a1 in my 98 integra ls. I have to use the ls power steering pump, with the b16 braket. Doing this places the bump about 1inch over so it does not line up with the crank pully. Im pretty sure i can find a way to make this work regardless. But my main quesiton is
Having them the pullys not line up, will this cause any harm to the powersteering system?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 »</TD></TR><TR><TD CLASS="quote">Does it line up with anything on the crank pully. I think on the older engines it used a v-belt for the power steering.</TD></TR></TABLE>
yeah they do use the vbelt... but im still using the ls power steering pump. I guess i could take the pully off the b16a1 pump and put it on my ls power steering pump. Which i have already tried but the vbelt i have is too short. I will try to get a longer belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 »</TD></TR><TR><TD CLASS="quote">Ya thats your best bet I have the same problem right now with mine but I don't have a spare v pully.</TD></TR></TABLE>
yeah the only problem ive encountered is the way the pullys connect to the pump. The ls pully has little spline (like gears) while the b16 (vbelt pully) does not. I will try to get some pictures when i get back for christmas break.
I was thinking of getting a different crankshaft pully but I spent lots of money balancing it so why mess with a balanced setup. I think i'll just loop my rack and leave it at that.
Mfoehrkolb
Sep 15, 2008 01:27 PM
UncleBen'sRacing
19
Feb 3, 2003 11:10 PM
