hot days
Old Sep 9, 2008 | 07:24 PM
eoris__ej1's Avatar
Default hot days
i need help with my a/c i swapped a gsr into my ej1. the gsr came with out an a/c or a/c brakets what parts can i use, is it posible to use the stock parts and how can i tell if the a/c motor works.
Old Sep 9, 2008 | 07:36 PM
tsdenny's Avatar
Default Re: hot days (eoris__ej1)
you can use your stock a/c compressor.
But you need to get the del sol vtec a/c bracket. dont know the part #
Old Sep 9, 2008 | 07:38 PM
6footmidget's Avatar
well for a 92-93 civic you need an r12 system and 94-95 you need a r134a system i dont know for sure but i think itll be like that for your gsr motor youll need the ac system specific to the motor and all the compressors, hoses, condensors, and what not to put onto your motor, now how to tell if it works? i dunno but yeah hope this helps!
Old Sep 9, 2008 | 07:42 PM
94EG8's Avatar
Seagull Management
Default Re: hot days (tsdenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsdenny &raquo;</TD></TR><TR><TD CLASS="quote">you can use your stock a/c compressor.
But you need to get the del sol vtec a/c bracket. dont know the part #</TD></TR></TABLE>
correct, you can also use a CR-V bracket as well.
Old Sep 9, 2008 | 09:45 PM
.Grimace's Avatar
footwork mastery
Default Re: hot days (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
correct, you can also use a CR-V bracket as well.</TD></TR></TABLE>
as well as 99-00 em1 ones also
you don't need to switch the compressor anything. just get the mount that goes on the block and your set. i think some companies like innovative mounts even sell them?
ATrin
12
Jul 22, 2006 08:47 AM
teamm_AP1
16
Jan 10, 2005 02:24 PM
GiT LaO'd
Jul 23, 2004 10:36 AM
CivicEx95
Apr 25, 2002 01:04 PM
Hard2Find
Feb 19, 2002 09:02 PM
