hot days
hot days
i need help with my a/c i swapped a gsr into my ej1. the gsr came with out an a/c or a/c brakets what parts can i use, is it posible to use the stock parts and how can i tell if the a/c motor works.
Re: hot days (eoris__ej1)
well for a 92-93 civic you need an r12 system and 94-95 you need a r134a system i dont know for sure but i think itll be like that for your gsr motor youll need the ac system specific to the motor and all the compressors, hoses, condensors, and what not to put onto your motor, now how to tell if it works? i dunno but yeah hope this helps!
Seagull Management
Re: hot days (tsdenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsdenny »</TD></TR><TR><TD CLASS="quote">you can use your stock a/c compressor.
But you need to get the del sol vtec a/c bracket. dont know the part #</TD></TR></TABLE>
correct, you can also use a CR-V bracket as well.
footwork mastery
Re: hot days (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">
correct, you can also use a CR-V bracket as well.</TD></TR></TABLE>
as well as 99-00 em1 ones also
you don't need to switch the compressor anything. just get the mount that goes on the block and your set. i think some companies like innovative mounts even sell them?
ATrin
12
07-22-2006 08:47 AM
CivicEx95
04-25-2002 01:04 PM
Hard2Find
02-19-2002 09:02 PM
