Car will not start
Old Sep 9, 2008 | 06:00 PM
JDMb20Ferio's Avatar
Default Car will not start
Ok heres what i've done to my car.
new spark plugs
new spark plug wires
new alternator
battery checked as good
new main relay
new valve cover gasket
ok, i left for tennessee 4 months ago. and let my car sit for 2 months.
it ran perfect before. I come back and it acts like it wants to start but wont turn over.
After I put all the new parts on I added some Lucas fuel injector cleaner in a full tank of gas and i let it sit for another month because we were having electrical problems which are fixed now. I just got in the car and it cranked right up, i drove about 2 miles and it sputtered down and died. and thats where she sits.
Only thing I can think that is wrong, is that the fuel system cleaner did not run all the way through and I have trash inside my fuel injectors. Every 5 tries it will crank, but with gas peddle to the floor the rpm's wont go over 1,000.
can someone help me on this?
Now the problem is.. The car will not
Old Sep 9, 2008 | 06:29 PM
89hatcher's Avatar
is it throwing a CEL?
Old Sep 9, 2008 | 06:35 PM
RedRacerCivic's Avatar
clogged fuel filter?
Old Sep 9, 2008 | 06:38 PM
89hatcher's Avatar
Default Re: (RedRacerCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRacerCivic &raquo;</TD></TR><TR><TD CLASS="quote">clogged fuel filter?</TD></TR></TABLE>
thats what i was also thinking.
Old Sep 9, 2008 | 06:55 PM
innes887's Avatar
hook a pressure gauge up to the fuel line and see what it is. should be around 35 at idle with a good fuel pressure regulator. also make sure you tightend up the rotor enough where it wont start wobbling
Old Sep 9, 2008 | 07:54 PM
Default Re: (innes887)
I dont think that would be it. I unhooked the fuel line too see if was clogged, and it wasnt.
it sprayed out pretty hard so i dont think that would be a problem.
Rotor? The distributor?
Old Sep 9, 2008 | 08:38 PM
acmoc's Avatar
Default Re: (JDMb20Ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMb20Ferio &raquo;</TD></TR><TR><TD CLASS="quote">I dont think that would be it. I unhooked the fuel line too see if was clogged, and it wasnt.
Rotor? The distributor?</TD></TR></TABLE>
Which one, the in or out
Old Sep 9, 2008 | 08:54 PM
Monkeyz1's Avatar
Default Re: (acmoc)
try changing the other relay, not the MAIN blocky looking one, but the one UNDER that one, it's your Fuel Injector relay. my car was out for 2 weeks, changed everything, checked for clogs and everything, spent like 300 on the car trying to figure out what was wrong with it then a friend of mine told me to change that relay, i went to the junkyard, bought it for like 2 dollars [or you can steal it, whatever lol] put it in, and the car started right up.
mandajane92
Honda S2000
Jul 22, 2013 09:37 PM
1sikhatch
Honda Civic (2001 - 2005)
24
Mar 21, 2010 02:49 PM
boostfever
Jul 8, 2009 04:11 PM
PinkMaggit
16
Nov 28, 2008 05:25 PM
z crx z vtec z
Jun 13, 2007 03:19 PM
