block decking question.
Old Sep 9, 2008 | 03:10 PM
killerpenguin21's Avatar
Default block decking question.
is there anyway to tell how much a block has been decked?
is there a common amount of material removed if it is just being done to ensure a flat surface?
does decking effect timing like decking the head (retard the timing by i believe 1 deg per thousandth)?
im asking because, the sleeved block i bought had no record of how much material was taken off. but was told it had been done probably 2-3 times (once for sleeve install, and once prior)
what do you think im looking at here?
Old Sep 9, 2008 | 03:23 PM
Lubo_25's Avatar
Default Re: block decking question. (killerpenguin21)
honda usually gives us about 3-4 circular indents on the block, depth mic them out to see where you stand and compare it to the oem deck height max. spec...its that simple if the block does not have any more left then measure from the aluminum main cap portion to the top of the deck with a big enough mic depending on the block...
Old Sep 9, 2008 | 03:36 PM
Default Re: block decking question. (Lubo_25)
yeah there is definetly still material above the little gauges. the block is at my parents house so without a visual im having a hard time figuring out how i could measure the height difference between that tab and the deck.
Old Sep 9, 2008 | 05:59 PM
96Spec Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 &raquo;</TD></TR><TR><TD CLASS="quote">is there anyway to tell how much a block has been decked?
what do you think im looking at here?</TD></TR></TABLE>
You will need a depth micrometer to measure how much has been removed. Decking a block does throw off valve timing just like when milling a cylinder head. This is why it is important to degree your cams to the specs on the cam card. If you dont have a the right tool bring it by any machine shop and ask them if they could check it for you.
Old Sep 9, 2008 | 06:25 PM
Default Re: block decking question. (96Spec Ek)
i can prolly buy the tool easier that finding a good machine shop near me
im just gonna need to figure out the timing somehow....i wanted to buy a degree but i just dont have the money.
Old Sep 9, 2008 | 06:33 PM
96Spec Ek's Avatar
If your anywhere near long island I could do it for you once the engine is done. What cams will you be running?
Old Sep 9, 2008 | 06:43 PM
im using pro1's, im kinda far from LI (hour north of the city), plus the car wont back on the road again until the spring most likely...thanks fr the offer tho.
Old Sep 9, 2008 | 08:09 PM
96 spec...check your pm's.
eg:R
Apr 19, 2014 08:56 AM
10SecDSM
Sep 15, 2006 08:11 AM
JFG Kevin
Jul 17, 2006 04:39 PM
preludesi93-arg
Jun 19, 2005 06:44 AM
