changed main relay, pump still wont prime! WTF
Old Sep 9, 2008 | 02:22 PM
thebleek's Avatar
Default changed main relay, pump still wont prime! WTF
ok so when i go to start my car i usually hear the fuel pump prime. well it stopped working. so i thought it would be the main relay. I changed out the main relay and i still have the same problem. my car wont start, my fuel pump wont prime, so wtf do i do.
Old Sep 9, 2008 | 02:25 PM
dumafit's Avatar
Default Re: changed main relay, pump still wont prime! WTF (thebleek)
check thermostat ground, that'll cause it to not prime
Old Sep 9, 2008 | 02:29 PM
sicones's Avatar
Default Re: changed main relay, pump still wont prime! WTF (dumafit)
You should have done some troubleshooting first before you buy/swap parts. Do you get 12V to the fuel pump connector, do you hear the main relay click, did you check the fuses, do you get 12V AT the main relay???
Old Sep 9, 2008 | 02:30 PM
Relic1's Avatar
blown fuse
bad electrical connection
bad pump
bad ECU (there's a cap inside the ECU that goes bad and causes no prime condition)
Old Sep 9, 2008 | 02:32 PM
thebleek's Avatar
Default Re: (Relic1)
i did diagnose before i bought items....
ecu fuse under hood is fine.
the ground that connects to the thermostat housing is all good and tight
i have a y7 and y8 ecu so i swapped them and they both do the same thing
my mechanic thought the pump was bad before, but it ended up being that thermostat housing ground. everything was working fine a few days ago and it just seems this happened out of no where. i wasnt driving the car or anything
Old Sep 9, 2008 | 02:38 PM
sicones's Avatar
Default Re: (thebleek)
Get a Helms manual and do the PGMFI troubleshooting procedure
Old Sep 9, 2008 | 02:48 PM
thebleek's Avatar
Default Re: (sicones)
ok so anyone correct me if im wrong...
but when you turn your key to ON you should hear a click from the main relay,
then you turn your key to start you should hear another click right?
well i dont hear the first click, but when i turn it to start i can feel the click thru the relay.
i have two relays and they both do the same, one is brand new
Old Sep 9, 2008 | 03:39 PM
sicones's Avatar
Actually this procedure is just to test the relay, you need to test the car.....but use it to see if you are getting the correct voltages and grounds using a meter...
Old Sep 9, 2008 | 04:52 PM
thebleek's Avatar
found the problem. it was the fuse under the hood to the left of the ecu fuze
it was called something like FI e/m or something
relic won. lol
Old Sep 10, 2008 | 03:31 PM
sicones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">did you check the fuses</TD></TR></TABLE>
Rick Overton
33
Aug 6, 2015 07:47 PM
slowpokecivic
Jul 26, 2012 07:37 PM
3easy21
Jun 11, 2012 07:27 PM
Got_EF8
Sep 24, 2008 10:38 PM
T-RO
Nov 7, 2003 03:30 PM
