Mini me swap with a y8 automatic head?
Old Sep 9, 2008 | 01:33 PM
Chaps1's Avatar
Default Mini me swap with a y8 automatic head?
Does it make a difference if the Y8 I plan on putting on my Y7 is automatic or manual? I know I need a manual ECU. But will the Head, intake and throttle body of of a automatic Y8 work or no?
Thanks!
Old Sep 9, 2008 | 02:34 PM
sicones's Avatar
Default Re: Mini me swap with a y8 automatic head? (Chaps1)
You need a manual intake manifold and throttle body, the head doesn't matter. You also need to do the 3 wire to 2 wire IACV conversion. Go to ff-squad.com and find the write-up.
Old Sep 9, 2008 | 09:08 PM
Chaps1's Avatar
Default Re: Mini me swap with a y8 automatic head? (sicones)
can you explain why the intake and manifold won't work. Also I searched ff squad and can't find the write up.
Thanks for your help!
Old Sep 9, 2008 | 09:13 PM
94EG8's Avatar
Seagull Management
The manual Y8 uses a different throttle body and intake manifold than the automatic, The automatic has the IACV on the throttle body while the manual has the IACV on the back of the intake manifold.
Old Sep 10, 2008 | 05:58 AM
Chaps1's Avatar
Default Re: Mini me swap with a y8 automatic head? (94EG8)
Awesome thanks!
Old Sep 12, 2008 | 11:50 PM
Chaps1's Avatar
Thanks for all your help guys. I found a great write up on doing the mini me. But I had a question about what ARP head studs to order? I'm not sure where / what combo to get.
Old Sep 13, 2008 | 01:18 PM
thumper64's Avatar
Y8 studs. Whatever you would buy for a Y8 head on a Y8 block. The Y5, Y7 and Y8 all share the same block, so it's funny we don't just say D16Y block or something.
Old Sep 13, 2008 | 09:57 PM
Chaps1's Avatar
Default Re: (thumper64)
okay thanks. I thought I had read somewhere that one of the studs was a y7 and the rest were y8, but thanks!
termite1r
10
Sep 2, 2013 10:29 AM
949
Nov 4, 2012 07:24 PM
GReddy_Civic
Aug 17, 2009 08:15 AM
dizzyek
Jun 25, 2006 03:01 PM
SOHC_Brian
Jan 15, 2004 08:57 AM
