vacume leak troubles!!!
i have a 91 hatchback with a d15 in it and it has a vacum leak. but the problem is that ive changed all the vacum lines and it stillhasnt fixed the problem and the only time my rpm's fluxiuate is when im at about 2000rpm and i think it might be my intake manifold gasket but im not too sure so any help will be much apreciated. thanks.
pull your IACV off and clean it....also make sure you have the vacuum lines goin to the right places...you may have them all connected, but if their not on right, than you will still get a fluctuating idle
i used this...for OP , the same steps apply for the d series
http://www.g2ic.com/forums/showthread.php?t=35534
better yet here is one for the d series
http://www.d-series.org/forums...35543
apbtwhiskey
Apr 5, 2013 01:51 PM
superhatchbackbros
Jan 26, 2012 01:03 PM
dc2_97teg
May 27, 2008 03:39 PM
