b20vtec bad idle and choke on rev's please help???
i just put the motor in today and put it all together and it starts right up.. it has low idle surge like 1200rpms when lil warm it jump 1200-1800rpms and drops back down! was thinking tb gasket leak?? i have a victor x intake manifold and a sk2 throttle body with a 68mm thermal gasket! could this be the problem? also the victor x manifold iacv weird looks like its universal d and b series iacv. i think i have a d series one on it right now. could that be a problem? also i put a new blox tps on it and did the ohms reading and they are correct.48ish closed and5.00 wot! or is it diff readings i should have? it seems to hold fuel pressure i set it for 45ish psi right now where should it be exactly? and when i give it short revs it wants to choke and die? wtf could be that problem? if i hold the gas down rev it up to like 3000rpms it seems to rev fine.. i dont get it can someone please give me some feedback.. i dont wanna f this engine up! well hope someone can help me.. thanks in advanced HONDA TECH MEMBERS
Re: b20vtec bad idle and choke on rev's please help???
ps everything is brand new! also keep trying to burp the engine's coolant system thinking thats the problem and also i dont have 02 sensor hooked up yet and im not geting no check engine codes? weird and im running a stock p28 at the moment. is that bad to do? should i use my lsvtec ecu to start it up and see what it does? or just get a stock p72 gsr ecu? maybe the p28's messing with the engine? please help
ok i got the voltage right thanks and no codes.. its weird i just started it up and it ran like 1200 till warm up and then it started going up and down not by alot tho.. hmmmmm
also i had it started and it idle high like 1200 and i disconnected the iacv and it keep runing as it was then soon as it warms up and then started to surge i diconnected the iacv and the car puttered and shut off! is that a bad iacv?
If you are using a d series harness, the iacv plug converts over from a 3 plug to a 2 plug, so that might be your problem right there.
andybmuzik
08-09-2013 08:23 PM
apbtwhiskey
04-05-2013 01:51 PM
Integra_Boi
08-21-2002 02:17 PM
