oil-restrictor
Old Sep 9, 2008 | 04:05 AM
madracer's Avatar
Default oil-restrictor
Hi,
I have a turbo installed in my 2000 civic si with a B16A2 motor this week and after i installed the downnpipe and dump tube with full exhaust, i notice that there was blue smoke coming out of the exhaust, i'm currently using -3AN oil line. I'm taking the oil from the back of the motor at the oil sending unit.
Does anyone know the fix to this problem???
Old Sep 9, 2008 | 08:56 AM
honda_joe's Avatar
Default Re: oil-restrictor (madracer)
Whats the story on the turbo? New/Used?
What size is the drain line? Check that real close for kinks or spots where flow would be impeded (low spots/tight corners).
Old Sep 9, 2008 | 03:17 PM
madracer's Avatar
Default Re: oil-restrictor (honda_joe)
The Turbo is new, The return line is -8AN but it was kink so i remove it today and bought new -8AN hose and fittings to put on tomorrow. The fitting coming out from the turbo was a straight fitting and it needed a 45-degree fitting so i bought one today.
I also bought some new NOS jets and made my own oil restrictor. I saw info on a website where Garrett show how to do this mod for all T3 or T4 Turbos.
Thank you...
Old Sep 10, 2008 | 04:30 AM
honda_joe's Avatar
I bet fixing that kink will solve the problem. Same thing happened on my setup when I used 1/2" heater hose as an *emergency* fix to get me to work one day. There was a huge kink and only about 1/4 was open. It looked like I was fogging for mosquitos
Old Sep 10, 2008 | 12:07 PM
madracer's Avatar
Hi,
I fix the -8AN return to the oil pan today, I bought a 45 degree fitting for the oil pan and a 45-degree fitting for the turbo end, the fittings can swivel all around.
So i then try it out without putting a oil restrictor and it worked perfectly, no more blue smoke thru the exhaust and no leaks thru the turbo. Keep in mind the oil feeder line is a -3AN, the -4AN was to big.
Thanks for your help and your opinions on your experience.
lunareg
Sep 5, 2010 01:00 PM
slo_crx
Oct 12, 2004 05:51 PM
alfee
Jul 30, 2004 02:42 PM
QWKVTEC
Apr 19, 2004 08:45 AM
DOHCarp
Mar 8, 2002 09:36 AM
