Torque Spec for rocker assembly D16A6.
Old Sep 8, 2008 | 11:55 PM
Broken Gearbox's Avatar
Default Torque Spec for rocker assembly D16A6.
Putting in a new camshaft. Whats the TQ spec for the rocker assembly?
T.I.A.
Old Sep 9, 2008 | 04:58 AM
fireant's Avatar
Default Re: Torque Spec for rocker assembly D16A6. (Broken Gearbox)
Oil up the camshaft, wipe the contact points and bolt holes clean.
Get the bolts hand-tight, then torque to 16# each.
Go in this order:
Cyl 3 (middle, front, back)
Cyl 2 (middle, front, back)
Cyl 4 (middle, front, back)
Cyl 1 (middle, front, back)
Then the seal holders on the ends are going to be 9# if you need to do them too.
Do a valve lash adjustment, drive it, then do another once its cooled off.
Modified by fireant at 9:45 AM 9/9/2008
Old Sep 9, 2008 | 11:28 AM
Default FV-QR
Thanks
Old Sep 9, 2008 | 11:57 AM
acmoc's Avatar
Default Re: Torque Spec for rocker assembly D16A6. (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Oil up the camshaft, wipe the contact points and bolt holes clean.
Go in this order:
Modified by fireant at 9:45 AM 9/9/2008</TD></TR></TABLE>
Wow . Thanks x2
RedGSR
Jun 6, 2005 03:07 AM
tonezilla
Feb 27, 2005 08:08 AM
drudy
Jan 31, 2005 03:03 PM
mnbv
Aug 16, 2004 10:05 AM
akhom
Oct 20, 2002 09:56 PM
