having problems with 2 codes and running
Old Sep 8, 2008 | 08:45 PM
tuname420's Avatar
Default having problems with 2 codes and running
i have a y7/z6 fully built low comp vitara build.. im throwing a code 10 and 14.. iacv and iat.. i have them mixed up and now i found out the way they need to hook up. but im still throwing iacv code 14.. the car doesnt idle really good and the motor shakes alot and sounds like a slight rod knock or maybe detonation.. the motor has 1k miles. it feels like it has no hp at all.. the bottom end is tottal **** till 5k and 5-8k rpm its still pretty slow but not much backfiring.. i cleaned the iacv and hooked it back up.. should i use a z6 map and wat can i do about the iacv cel and my car running like total ****.
Old Sep 8, 2008 | 09:30 PM
90sedan's Avatar
Default Re: having problems with 2 codes and running (tuname420)
You engine is going to run like complete **** till you fix code 14. Try replacing the sensor with a known good sensor to see if that does it, if not, it's a wiring issue.
Old Sep 8, 2008 | 10:17 PM
tuname420's Avatar
could it be the ecu if i had the 2 white plug wires switched and the green one?
OgulcanTR
Sep 13, 2018 10:09 PM
turbodohcsi
Nov 26, 2005 09:46 PM
