HELP!!!!
Old Sep 8, 2008 | 07:27 PM
jdmek2277's Avatar
Default HELP!!!!
Modified by jdmek2277 at 7:42 PM 10/13/2008
Old Sep 8, 2008 | 09:37 PM
.Grimace's Avatar
footwork mastery
Default Re: HELP!!!! (jdmek2277)
sounds like a head gasket to me
Old Sep 9, 2008 | 03:32 PM
jdmek2277's Avatar
Default Re: HELP!!!! (.Grimace)
could a headgasket really cause to loose compression
Old Sep 9, 2008 | 03:38 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek2277 &raquo;</TD></TR><TR><TD CLASS="quote">could a headgasket really cause to loose compression</TD></TR></TABLE>
Yes, very yes
Old Sep 9, 2008 | 03:52 PM
jdmek2277's Avatar
Default Re: HELP!!!! (94EG8)
but couldnt rings also be a possibility?? thats wat i am scared about
Old Sep 9, 2008 | 04:15 PM
jdmek2277's Avatar
please guys i need to know if it can be the headgasket or if im lookin at new rings
Old Sep 9, 2008 | 04:20 PM
94EG8's Avatar
Seagull Management
Could be rings, but i'm leaning more towards head gasket on this, honestly I think i'd prefer to have bad rings than a bad head gasket.
Old Sep 9, 2008 | 04:29 PM
jdmek2277's Avatar
how come??? changing a headgasket seems like a piece of cake rather than changing the rings....and is there a way i can make sure of what it is.....i did the compression test and when i put a cap full of oil in the cylinder the compression went to 180 does this mean its the rings....and if so is it weird jus one piston has bad rings??????
Modified by jdmek2277 at 5:47 PM 9/9/2008
Old Sep 9, 2008 | 04:58 PM
jdmek2277's Avatar
Old Sep 9, 2008 | 05:28 PM
redline870's Avatar
u answered your own question. if u put oil in the cylinder and the compression goes up it usually means bad rings
Old Sep 9, 2008 | 05:42 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek2277 &raquo;</TD></TR><TR><TD CLASS="quote">how come??? changing a headgasket seems like a piece of cake rather than changing the rings....</TD></TR></TABLE>
Yeah its easier, but it seems like if you blow a head gasket once they just keep blowing, bad rings you hone the cylinder, replace and thats it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek2277 &raquo;</TD></TR><TR><TD CLASS="quote">i did the compression test and when i put a cap full of oil in the cylinder the compression went to 180 does this mean its the rings....and if so is it weird jus one piston has bad rings??????</TD></TR></TABLE>
Thats probably bad rings if oil improved compression, if its just one piston its possible its possible that one piston has a stuck ring.
Old Sep 9, 2008 | 07:44 PM
jdmek2277's Avatar
thanks guys looks like im going to rebuild
bvillarreal
Aug 22, 2013 09:43 PM
2fast4u831
17
Aug 29, 2004 02:29 AM
accord19
Feb 23, 2004 04:30 AM
EARLdaSQUIRREL
10
Aug 8, 2003 02:43 PM
BoostedSi
Apr 20, 2002 04:21 PM
