Comptech Icebox on a Stock ITR Intake Arm?
Old Sep 7, 2008 | 11:58 PM
Tuner Eddy's Avatar
Default Comptech Icebox on a Stock ITR Intake Arm?
Hey fella's, I have seen several pictures of guys running comptech icebox's on factory itr intake arms.
I am currently in the process of putting a jrsc on my em1, and have an itr intake arm with a comptech icebox that I ordered last week. I got the parts in and it seems as if I am going to have to modify the intake arm to make everything fit by making it a little thicker.
I know my car is not an itr, but I figured that some of you were running this setup. If you are, what air filter are you running?
Any thoughts/help is greatly appreciated.
Old Sep 8, 2008 | 04:49 AM
Tuner Eddy's Avatar
ttt
Old Sep 8, 2008 | 06:40 AM
CW-ITR's Avatar
Default Re: Comptech Icebox on a Stock ITR Intake Arm? (Tuner Eddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuner Eddy &raquo;</TD></TR><TR><TD CLASS="quote">.....I know my car is not an itr, but I figured that some of you were running this setup. If you are, what air filter are you running?......</TD></TR></TABLE> Comptech air filter ofcourse On a serious note, I seem to recall that both the Comptech air filter and the OEM filter are the same dimension. I'll check mine tonight after work.
Old Sep 8, 2008 | 07:53 AM
mugenr#1011's Avatar
Default Re: (Tuner Eddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuner Eddy &raquo;</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
you dont do that in this forum that is in the fs thread's
just get a comptech filter
Old Sep 8, 2008 | 06:14 PM
megatran808's Avatar
I had a K&N filter on mine.
Old Sep 8, 2008 | 08:13 PM
DiRT!'s Avatar
Default Re: Comptech Icebox on a Stock ITR Intake Arm? (megatran808)
Found this
Old Sep 8, 2008 | 08:30 PM
00TypeR1071's Avatar
Default Re: Comptech Icebox on a Stock ITR Intake Arm? (DiRT!)
Yes, Comptech filter and OEM ITR fit the same way!
Here is my contribution
Old Sep 8, 2008 | 09:08 PM
Reyes's Avatar
Default Re: Comptech Icebox on a Stock ITR Intake Arm? (00TypeR1071)
i have thisset-up, i'm using a comptech filter in mine too,
Old Sep 8, 2008 | 11:10 PM
Fatchance187's Avatar
Default Re: Comptech Icebox on a Stock ITR Intake Arm? (Reyes)
Yeah there are a couple K&N filters that work as well. I remember seeing what numbers they were after a quick search....
https://honda-tech.com/zerothread?id=2049577
https://honda-tech.com/zerothread?id=733432
https://honda-tech.com/zerothread?id=238120
Old Sep 9, 2008 | 07:20 AM
ITR-965's Avatar
That won't work on a JRSC... You will need a gsr stock arm to make it work. The JRSC sits too low for the ITR stock arm to work an the gsr arm works just fine for it.
I know from experience that will not work and you will need a gsr stock arm to get the icebox to work with the JRSC unless you get the Comptech arm designed for the JRSC.
Old Sep 9, 2008 | 09:12 AM
Default Re: (ITR-965)
what about the Comptech arm for a GSR? Will that work with the JRSC?
Old Sep 11, 2008 | 12:31 AM
Namrock's Avatar
Nice! Going to do that when i get a chance!
alscrx
Apr 5, 2009 06:39 PM
Tuner Eddy
Sep 9, 2008 05:45 AM
.:Made in OC:.
Apr 3, 2008 09:52 PM
