Another D16Z6 issue! Water pump (?)
Old Sep 7, 2008 | 09:43 PM
xnvb's Avatar
Default Another D16Z6 issue! Water pump (?)
Ok, so it seems that cliche about "when it rains, it pours" is rather on-point with my newest Civic. Just when I get one thing figured out, something else seems like it's going wrong.
As mentioned in the topic title, I have a D16Z6, and it's started making a weird whirring/screeching/squealing sound sporadically when idle and while driving. It's not consistent, doesn't only happen when accelerating or anything. It's coming from the right side of the engine, and sounds like possibly down near the block.
I initially thought perhaps it was a belt that was loose, or about to break or something, but then another friend of mine said it might be the water pump, which if I remember correctly, is in the area the sound seems to come from.
So...any thoughts? Anything I should check out in addition, to confirm what the problem is? If it is the water pump, are those terribly difficult to replace?
Old Sep 8, 2008 | 07:16 AM
xnvb's Avatar
Default Re: Another D16Z6 issue! Water pump (xnvb)
No one with any ideas or similar problem?
Old Sep 8, 2008 | 07:22 AM
blkegcoupe's Avatar
From: ....................................................................................................
i highly doubt its the water pump sounds like an alt belt or the alt itself go get it checked they do it for free at autozone and to check if its the water pump there are weep holes if you see coolant coming out of it then its the water pump also you would a liltte bit of coolant not alot
Old Sep 8, 2008 | 07:24 AM
crxcess's Avatar
Default Re: (blkegcoupe)
sounds like a loose belt.
Old Sep 8, 2008 | 07:28 AM
Pothole987's Avatar
Default Re: (crxcess)
could be the power steering pump making the retarded noise, have you flushed your system lately? i did mine, quiet as can be.
Old Sep 8, 2008 | 04:36 PM
xnvb's Avatar
Default Re: (Pothole987)
I don't have power steering, so I'm going to guess it's not that. At least I hope not, lol.
Old Sep 8, 2008 | 04:42 PM
xnvb's Avatar
@ blkegcoupe
I don't notice any coolant coming from it, so I'm guessing the water pump is safe. I was actually headed to AutoZone tonight to pick up some small parts, I'll have them check it out there and hopefully find out what's up. Thanks everyone
Old Sep 8, 2008 | 04:43 PM
jimmy o.'s Avatar
do you still have A/C?
Old Sep 9, 2008 | 12:35 AM
xnvb's Avatar
Default Re: (jimmy o.)
I have no AC either.
Old Sep 9, 2008 | 06:59 AM
EJ1_Ex's Avatar
Default Re: (xnvb)
check your alternator belt!
Old Sep 9, 2008 | 10:16 AM
JDM-JAMES's Avatar
its the water pump my d15b7 was making the same noise after a few days is started to leak and now its all fixed
W95civicEXcoupe
Apr 27, 2015 04:33 AM
95_eGsix
Apr 14, 2010 06:44 AM
hmtcrxsir
Dec 30, 2008 08:00 PM
OrangeBoost
Mar 24, 2005 08:43 AM
