My oil feed on the turbo is different than what stealthmode sent me...
Old Sep 7, 2008 | 07:54 PM
aleks77's Avatar
Default My oil feed on the turbo is different than what stealthmode sent me...
hey guys in the process of installing my turbo, went to install the feed line and its different than what it is on the turbo. I mean i can screw the yellow fitting in there, the threads are same, but i cant get a wrench on it to tighten it. I was able to get it pretty tight by twisting the whole line, but im not sure if thats good enough. Anyone got any ideas? Thanks a lot!
Old Sep 7, 2008 | 07:59 PM
tony413's Avatar
these are my best friends next to my torque wrenches and micrometers
http://www.gearwrench.com/cata...e_box/
my exact sets
Old Sep 7, 2008 | 08:01 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
the pictures are distorted is it not the right size or not threading. if it's not threading find out the thread pitch and contact stealthmode
Old Sep 7, 2008 | 08:43 PM
aleks77's Avatar
no the threading is correct, but i have no way to tighten it cause it goes really deep into the hole...i cant get any kinda tool on the fittin to tighten in...
Old Sep 7, 2008 | 08:48 PM
tony413's Avatar
Default Re: (aleks77)
have you tried the tool in my link
Old Sep 7, 2008 | 11:35 PM
aleks77's Avatar
the gear wrenches....? thats what i see when i click it
Old Sep 8, 2008 | 03:55 AM
B18EG6's Avatar
well you can use a socket to tighten the brass fitting. I had to use a set of crowsfeet to tighten the SS line, have you tried a crowsfoot?
Old Sep 8, 2008 | 05:14 AM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks77 &raquo;</TD></TR><TR><TD CLASS="quote">the gear wrenches....? thats what i see when i click it</TD></TR></TABLE>
yes they are ratching box wrenches
Old Sep 8, 2008 | 05:35 AM
tony1's Avatar
Default Re: (tony413)
The 1/8 NPT port on the turbo is recessed in the housing, you will not be able to use the fitting you have. You need a longer end on the 1/8 NPT male side of the fitting. I don't think you're going to find one that is what you need in one piece, you'll most likely have to get a 1/8 NPT to 1/8 NPT male to male adaptor that's about 1" long to thread into the turbo and then adapt from there.
Or buy an oil feed adaptor flange and bolt it to the CHRA and thread the feed fitting into that. I'm sure Stealthmode will help you out on it, have you contacted him? If you can't find what you need we have the feed flanges in stock.
Old Sep 8, 2008 | 06:43 AM
Schister66's Avatar
Man U FTW
...the next time you take pictures, find the flower button aka macro setting. That way we dont have to look at a bunch of blurred pictures.
Old Sep 8, 2008 | 08:03 AM
aleks77's Avatar
cell pix, my camera is busted sorry for the crappy pics.
This is a huge rush, the car is scheduled for tuning tommorow, so im gonna grab a 1/8th extension like tony mentioned and use that. Id like to do an AN setup down the road.
Thanks for all the help guys
BoostinTEG
Apr 8, 2011 07:33 AM
civickiller
Dec 11, 2009 06:34 PM
daluv
Jul 31, 2008 12:20 PM
Del$olB16A3
May 31, 2005 04:16 PM
