Question about keyless entry
Old Sep 7, 2008 | 03:25 PM
Bone-23's Avatar
Default Question about keyless entry
I have a 1997 civic HX i was wondering since the car did not come with keyless entry. If i order some keyring remotes will i be able to use it with my stock radio even though its an hx radio? I think if i put my stock radio back in and get some remotes all i'll have to do is program it to accept my remotes, is that true? Also if you have any other info about anything having to do with keyless entry post it up.
PS is there any nicer looking key fobs from newer honda/acura cars that i can use?
Old Sep 7, 2008 | 07:23 PM
TheJGB3's Avatar
You can get the keyless entry remotes for the HX and LX here
http://www.handa-accessories.com/civic98.html
Old Sep 7, 2008 | 07:26 PM
Bone-23's Avatar
Thanks for the help man.
Old Sep 7, 2008 | 08:37 PM
NOFX's Avatar
H-T White Ops
Default Re: Question about keyless entry (Bone-23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone-23 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1997 civic HX i was wondering since the car did not come with keyless entry. If i order some keyring remotes will i be able to use it with my stock radio even though its an hx radio? I think if i put my stock radio back in and get some remotes all i'll have to do is program it to accept my remotes, is that true? Also if you have any other info about anything having to do with keyless entry post it up.
PS is there any nicer looking key fobs from newer honda/acura cars that i can use?</TD></TR></TABLE>
You need the correct remote ('96-'98 are different from '99-'00 btw; you want the one with the OPTION button) and you need the correct radio. The correct '96-'98 radio will have a black antenna on the back of the radio.
Old Sep 7, 2008 | 09:00 PM
Frickr's Avatar
Default Re: Question about keyless entry (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
You need the correct remote ('96-'98 are different from '99-'00 btw; you want the one with the OPTION button) and you need the correct radio. The correct '96-'98 radio will have a black antenna on the back of the radio.</TD></TR></TABLE>
great thanks too, just figured out why my friend couldnt get the remote i gave him from my car (2000) to work on his 98.
Old Sep 7, 2008 | 09:56 PM
TheJGB3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">NOFX - You need the correct remote ('96-'98 are different from '99-'00 btw; you want the one with the OPTION button) and you need the correct radio. The correct '96-'98 radio will have a black antenna on the back of the radio.
The link I provoded was for '96-'98 model HX & LX
Old Sep 7, 2008 | 10:06 PM
NOFX's Avatar
H-T White Ops
Default Re: (TheJGB3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheJGB3 &raquo;</TD></TR><TR><TD CLASS="quote">The link I provoded was for '96-'98 model HX & LX</TD></TR></TABLE>
I wasn't replying about the link.
The HX and LX radios should already have the antenna though. The CX optional radio and DX radios do not have antennas on the radio already. The antenna looks like a black plastic scaffold piece on the backside of the radio.
I hadn't told him he needed to swap his radio. I just said he needed the correct one.
Old Sep 8, 2008 | 06:14 PM
Bone-23's Avatar
Any key will work so long as its 96-98?
Old Sep 8, 2008 | 08:55 PM
NOFX's Avatar
H-T White Ops
Default Re: (Bone-23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone-23 &raquo;</TD></TR><TR><TD CLASS="quote">Any key will work so long as its 96-98?</TD></TR></TABLE>
I figure you mean the remote. You need the '96-'98 keyless remote. I'm not sure which other models use the same remote fob off hand, but your best bet is one from a '96-'98 Civic.
rawrjaay
18
Jun 26, 2011 04:53 PM
odidipissuoff
10
Dec 26, 2009 07:28 AM
mikegsg9
Honda Civic (2001 - 2005)
20
Jul 25, 2006 12:48 PM
Apocalypse
May 13, 2004 11:19 AM
