stock 1997 civic hx keyless entry help
Old 06-26-2011, 12:38 PM
rawrjaay's Avatar
Default stock 1997 civic hx keyless entry help
when i bought the car with the stock radio, the remote and KE(Keyless Entry) worked perfect all the time.
So I installed my own sound system which included a pioneer deck, so i took the stock radio out.
For about a couple months everything was good but then one day, my car wouldnt unlock? I changed the batteries in the remote and it still would not unlock?
so my questions are:
1. is there any way to program a new remote/KE to the car with the aftermarket deck in my car?
2. What may be the cause to the problem where the car wont unlock?
3. How do i use the vallet button? i no where it is at, but i have no idea what it does or how to use it.
please answer all questions, thanks!
Old 06-26-2011, 01:06 PM
The Grumpiest
grumblemarc's Avatar
Default Re: stock 1997 civic hx keyless entry help
Did the car not want to lock after you removed the stock radio?
Old 06-26-2011, 01:51 PM
rawrjaay's Avatar
no no no when i removed the stock stereo, everything worked fine like i said.
it always locked, but it had trouble sometimes unlocking.
and i no there is a valet button but i dont no how to use it..
Old 06-26-2011, 02:59 PM
rawrjaay's Avatar
would anyone else be able to help ?
Old 06-26-2011, 03:07 PM
Syndacate's Avatar
I'm a bit lost as to how it was working fine after you removed the stock radio. As far asI know the receiver is on the rear - it should not work if there is no receiver. You sure you used it in the time when you put the pioneer deck in to when it stopped working?
Old 06-26-2011, 03:11 PM
The Grumpiest
I'm thinking there is an aftermarket alarm with keyless entry.
Old 06-26-2011, 03:17 PM
rawrjaay's Avatar
ive had that pioneer deck in for a long time now
and it worked like i said perfectly fine till one day i came out of work
at 9 oclock pm
then it wouldnt want to unlock the car so i couldnt start the car without the keyless entry unlocking then after two hours of trying, it finally unlocked.
i just went outside and locked it with remote, then unlocked it again and it worked fine. but there is a problem like i said, sometimes it will not unlock.
Old 06-26-2011, 03:18 PM
rawrjaay's Avatar
and i have no idea how ur confused, its not confusion im seeking after, its plain and simple about what i believe is to be wrong.
rawrjaay's Avatar
can u explain this a little more please?
Old 06-26-2011, 03:24 PM
The Grumpiest
Is this the factory keyless entry you are talking about or is it aftermarket?
If it is factory it cannot work without the radio since it's part of the radio. Remove it and you have no factory keyless entry system.
If you have a valet switch then we're talking about aftermarket and then it's not a Honda issue.
Old 06-26-2011, 04:38 PM
rawrjaay's Avatar
ok well there is a button on the bottom near the clutch pedal,
and i am pretty positive this is a factory alarm im not sure to tell the truth i bought it from a person that already had it on there, i figured it was factory because of the stock stereo in the car at the time
Old 06-26-2011, 04:40 PM
The Grumpiest
There is no way that it's factory anything with the factory radio gone. It's aftermarket so it's not a Honda issue.
Old 06-26-2011, 04:43 PM
rawrjaay's Avatar
also this is the remote for the keyless entry
thats how it looks:
Uploaded with ImageShack.us
The Grumpiest
That is NOT stock.
Old 06-26-2011, 04:45 PM
rawrjaay's Avatar
im confused, just because theres a pioneer deck i dont no why its all of a sudden not a honda product.
i just want help to fix this problem. thanks
rawrjaay's Avatar
That is NOT stock.
how do u no thats not stock?!?!?!?!
Old 06-26-2011, 04:48 PM
The Grumpiest
That's not a stock fob. Not like any I've seen.
Old 06-26-2011, 04:51 PM
rawrjaay's Avatar
ok then what should i do then???
about the keyless entry?
im not to sure what to do now that i no its not stock...
Old 06-26-2011, 04:53 PM
The Grumpiest
Take it to a car audio and security shop.
odidipissuoff
10
12-26-2009 07:28 AM
Bone-23
09-08-2008 08:55 PM
cilvia
07-07-2005 01:11 PM
YipMan_Style
Audio / Security / Video
09-28-2003 09:25 PM
Quick Reply: stock 1997 civic hx keyless entry help
