Weld Steel to Cast Iron>????
Old Sep 7, 2008 | 10:10 AM
vy3tnamezz's Avatar
Default Weld Steel to Cast Iron>????
i have a cast iron turbo manifold. i want to upgrade to external wastegate, but cannot not find the manifold that will fit my turbo with the external waste gate flange. i was wondering can i just weld a external wg flange onto my manifold??? this would be the cheaper way for me to do this instead of changing my whole set up.. will this work>?? how good will it hold.?? anyone done this before??
Old Sep 7, 2008 | 10:00 PM
Longitudinal's Avatar
Default Re: Weld Steel to Cast Iron>???? (vy3tnamezz)
If done right, it will hold. I have done it a few times. Welding MILD (not stainless, don't want to mix stainless and cast iron from what I understand) steel to cast iron is actually easier than welding iron to iron.
When welding iron, you must take care to pre- and post-heat the iron. Weld in short (1" tops) sections then pick up the torch and heat the piece to allow heat to distribute evenly in the iron before continuing. If heat is distributed too unevenly, the iron will crack, even shatter, when it cools.
When I have welded cast iron, it has always been stick welding with cast iron electrodes. TIG is also possible. One of the TIG fillers is 85% Nickel. I have not used a TIG on cast, so I cannot say any more about that, but I have never had one of my cast welds break.
Old Sep 8, 2008 | 10:27 PM
vy3tnamezz's Avatar
Default Re: Weld Steel to Cast Iron>???? (Longitudinal)
ok thanks a lot. i think im just going to take it to a professional to do it. just wanted to make sure if is possible
Old Sep 9, 2008 | 02:38 AM
i drive a honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Longitudinal &raquo;</TD></TR><TR><TD CLASS="quote">If done right, it will hold. I have done it a few times. Welding MILD (not stainless, don't want to mix stainless and cast iron from what I understand) steel to cast iron is actually easier than welding iron to iron.
When I have welded cast iron, it has always been stick welding with cast iron electrodes. TIG is also possible. One of the TIG fillers is 85% Nickel. I have not used a TIG on cast, so I cannot say any more about that, but I have never had one of my cast welds break.</TD></TR></TABLE>
yup, tig will f up real fast from the sand that's in the iron (sand cast)
Old Sep 9, 2008 | 06:50 AM
Default Re: Weld Steel to Cast Iron>???? (i drive a honda)
Oh, yeah, sand reminds me that you must clean the surface thoroughly. Grind to a nice, shiny surface. The dull bumpy part on the outside of a piece of cast iron is a casting skin that is loaded with impurities, including sand. Sand doesn't weld very well, and you WON'T be burning it away.
Old Sep 9, 2008 | 06:38 PM
vy3tnamezz's Avatar
ok thanks again. i will make sure of that.
KdF
Sep 23, 2010 07:14 PM
slowhitEJ1
Welding / Fabrication
Aug 24, 2009 08:24 AM
CA6VTEC
Feb 24, 2006 07:24 PM
yusoslo
Sep 8, 2004 12:49 PM
slooogsr
Nov 5, 2003 02:59 PM
