Painting Rollbars and or Cages
I did a search on this and wanted to know what paint you guys are using. If anyone is rattlecanning it, or if its just being powdercoated etc...
I wanna do this myself. I dont own a paintshop, nor do I own any of the equipment. But I know how to do things right such as stripping, priming, and laying down coats. I want to use the best paint possible though so it takes to my rollbar.
any suggestions? Thanks in advance...
It's all in the prep work. Prep it well, use a wet on wet sealer suitable for bare metal. Then lay your base/clear or single stage right after the sealer has flashed.
Prep work and high quality materials will make the difference in durability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerflow »</TD></TR><TR><TD CLASS="quote">It's all in the prep work. Prep it well, use a wet on wet sealer suitable for bare metal. Then lay your base/clear or single stage right after the sealer has flashed.
Prep work and high quality materials will make the difference in durability.</TD></TR></TABLE>
works for me...right on. I might just make this one of my winter projects.
em Dot
13
Jun 14, 2007 08:19 PM
turbotime
17
Mar 29, 2007 07:50 PM
