Oil Light On During Idel
Im having alittle trouble with the civc, Maybe you could help me come up with a soultion?
I was having problems of leakage with my old pan so I got another one and welded a -10 fitting on to it. Welded the fitting inside the pan and out, Bough a SS -10 line with areo fit fittings. Well Today I had a little extra time at the shop so I went ahead and installed it all. Thinking this would solve all my problems Right.. Well it didnt lol. Now my oil light comes on when Im at idel and there is small amounts of oil in between the Hot and Cold sides of the turbine. I checked the oil level and its kinda over the fill mark. Any Ideas?
Along with this problem My boost gauge reads 25hmg of Vacum this scares me because it never used to do this and my gauge tops out at 30 lol. When I first installed everything it would read 15 (tops 20)
Let me know what you think.
Car: 1995 civic Eg Obd1
Engine: B16 Oem H.G with ARP headstuds,
Turbo: T3 To4e open 3in D.p
I'd try a new oil pressure sending unit, see if that makes a difference. Dad had an old dakota that the oil light would come on in at idle all the time and we put a new sending unit on it and it turned out thats all it was. If that doesn't help put a manual oil pressure gauge on it, if the oil pressure is low i'd say its time for a new oil pump.
I just want to make sure that it is the pump before I go digging into it to find out its some thing else.
Could to much oil cause the light to come on?
Im thinking I might just try to find another blcok
no too much oil would not make it come on. why a new block when you could try what 94eg8 said. it's what i was getting at with your oil pump probably on it's way out.
I just dont want to.. Buy an oil pump install it just to find out its something else (Rod bearing, rings ect)
I have been reading other oil light threads and people keep saying that the OEM Honda CTR crank pulley's are a cause to this also???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks »</TD></TR><TR><TD CLASS="quote">hmm so yhou have super low and dom has super high</TD></TR></TABLE>Im lost lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR_B »</TD></TR><TR><TD CLASS="quote">I just dont want to.. Buy an oil pump install it just to find out its something else (Rod bearing, rings ect)
I have been reading other oil light threads and people keep saying that the OEM Honda CTR crank pulley's are a cause to this also???</TD></TR></TABLE>
I havent heard it about the CTR pulleys but I have heard that about other crank pulleys due to the harmonics...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">I'd try a new oil pressure sending unit, see if that makes a difference. Dad had an old dakota that the oil light would come on in at idle all the time and we put a new sending unit on it and it turned out thats all it was. If that doesn't help put a manual oil pressure gauge on it, if the oil pressure is low i'd say its time for a new oil pump.</TD></TR></TABLE>
x2 except I'd say electric oil pressure gauge (mechanical can fail or line can fail and poof you have a floorboard/dashboard full of oil and none in your engine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 »</TD></TR><TR><TD CLASS="quote">
I havent heard it about the CTR pulleys but I have heard that about other crank pulleys due to the harmonics...</TD></TR></TABLE>
When I put this motor together 3years ago I did not hear anything bad about them As this is an OEM Honda Crank pulley. As you said I did hear this about other Knock off types
slikz714
Feb 22, 2010 01:53 PM
