HELP!!!
I have an EG6 and i recently swapped it with a B16A2 USDM 99-00 Civic Si Motor and after like a week it starting smoking and overheating!?!? Any thoughts why? It is currently laying in my garage as i don't want to drive it and harm it more. It is my only car and i spent most my money on the swap. My homie said the swap only had around 60k.
60k isn't necessarily an indicator that the motor is in good shape. I've seen great condition motors with 150k on them and horrible condition motors with 15k on them. As mentioned, the symptoms point toward the head gasket.
Was it running fine for the first week?
Do you have a history of the swapped engine?
Is your coolent level low? I would guess so if it's overheating. Sounds like there is a 99% chance it's your head gasket.
Get a clean drain pan and drain your oil. If there is water/coolent in your oil, then that's a definite sign.
A head gasket is not a major project. Just be sure to get the proper gasket and a Helms manual. Key is to make sure you re-torque the head bolts down in their proper sequence per the Helms manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman »</TD></TR><TR><TD CLASS="quote">Was it running fine for the first week?
A head gasket is not a major project. Just be sure to get the proper gasket and a Helms manual. Key is to make sure you re-torque the head bolts down in their proper sequence per the Helms manual.</TD></TR></TABLE>
Yeah the first week it was running fine. All i know about the motor was that it had around 60-65k. Coolants fine. I'll drain my oil. I might as well get a complete tune up too. I'll have my friend install my head gasket. i'll get a spoon one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esean93 »</TD></TR><TR><TD CLASS="quote">does the smoke smell like nitrogen?could be ur egr valve.</TD></TR></TABLE>
What EGR valve. The only 6th gen civic with an EGR valve has a D16Y5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esean93 »</TD></TR><TR><TD CLASS="quote">r u sure ur thermostats not closed and the cooling fan kicks in?</TD></TR></TABLE>
While this stuff can be the cause of an overheating issue he's blowing white smoke, meaning burning coolant, meaning blown headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esean93 »</TD></TR><TR><TD CLASS="quote">does the smoke smell like nitrogen?could be ur egr valve.r u sure ur thermostats not closed and the cooling fan kicks in?</TD></TR></TABLE>
I don't know how nitrogen smells so iono? Cooling fan kicks in as it was running perfect yesterday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">Are you the coolant isn't low? It shouldn't overheat with full coolant and a bad head gastket fits the symptoms.</TD></TR></TABLE>#
Hmmm I'm sure the coolant isn't low because i added the coolant right after i swapped the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esean93 »</TD></TR><TR><TD CLASS="quote">does the smoke smell like nitrogen?</TD></TR></TABLE>
Nitrogen is odorless bud.
OMGZ 6 semesters of chemistry I can finally use!!!!1oneone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonPowered »</TD></TR><TR><TD CLASS="quote">#
Hmmm I'm sure the coolant isn't low because i added the coolant right after i swapped the motor.</TD></TR></TABLE>
I mean go out and check if it's low now.
I mean go out and check if it's low now.</TD></TR></TABLE>
Yeah its not low. Just checked right now.
lol good for u man!i think that something thats smokes too when egr valve isnt workin and it smells bad.i kno it because im having the problem with my stock motor
Ordered a Spoon headgasket. Will get it installed on wednesday or so. Currently driving my moms minivan LMAO
Modified by SpoonPowered at 4:43 PM 9/7/2008
Modified by SpoonPowered at 4:44 PM 9/7/2008
oakraidersnum1
Mar 9, 2008 01:53 PM
headrec*
Nov 16, 2007 06:40 PM
