15w50 full synthetic
Old Sep 6, 2008 | 01:53 PM
builtITRm22x's Avatar
Default 15w50 full synthetic
Hey guys I'm currently on a budget due to FULL TIME STUDENT and my ITR needs oil change real bad. I have Mobil 1 full synthetic 15w50 sitting in my friends garage. You think my motor can get harmed by using 15w50 then switching back to 5w30 Mobil 1 full synthetic ASAP?
Old Sep 6, 2008 | 03:00 PM
meots98itr's Avatar
Default Re: 15w50 full synthetic (builtITRm22x)
no harm you'll just notice a slow response.
Old Sep 7, 2008 | 08:09 AM
Dang EG's Avatar
Default Re: 15w50 full synthetic (meots98itr)
You previously posted that you had a new motor going in, you should stick with the break in procedure. Get cheap normal oil for now and then when the time comes, switch to synthetic oil of your choice.
Old Sep 7, 2008 | 05:11 PM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meots98itr &raquo;</TD></TR><TR><TD CLASS="quote">you'll just notice a slow response.</TD></TR></TABLE>
Modified by Erik95LS at 1:31 AM 9/8/2008
Old Sep 7, 2008 | 08:31 PM
TOO MUCH TORQUE's Avatar
so thick, its going to do a bad job of lubricating
Old Sep 7, 2008 | 09:15 PM
highroller54's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meots98itr &raquo;</TD></TR><TR><TD CLASS="quote">no harm you'll just notice a slow response.</TD></TR></TABLE>
wtf
Old Sep 7, 2008 | 09:53 PM
coolhandluke's Avatar
Default Re: 15w50 full synthetic (highroller54)
Please do not listen to this non-sense. Higher weight oil has a higher viscosity at startup. Simply put, roughly 90% of engine damage occurs on startup. Thinner oil has better lubricating properties, it transfers heat more effectively. I'm a college student paying my way through college, so I know your position. However, this is an item you cannot cheap out on. eat beans and rice for a week, that will make up the difference. Kinda sets the tone for this a quote; "The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory." -Aldo Gucci
Old Sep 7, 2008 | 10:51 PM
Erik95LS's Avatar
Default Re: 15w50 full synthetic (coolhandluke)
15w-50 for 5+ years with no issues. It won't hurt anything, but unless you're tracking quite a bit in high heat, there's no real need.
Old Sep 7, 2008 | 11:01 PM
slofu's Avatar
If you ran it where it was actually cold I'd advise you to bite the bullet and buy the lighter-weight oil. However, I highly doubt that in SoCal it's going to make a significant difference.
What will certainly help, in any case, is to supplement your oil with Zinc, as most oils currently lack enough of it, and it helps in engines using flat-tappet cams. STP oil treatment is good for it.
Old Sep 8, 2008 | 11:20 PM
IN VTEC's Avatar
Default Re: 15w50 full synthetic (slofu)
The Mobil 1 15W-50 does have higher Zinc levels. Not as much as say Valvoline VR-1 or Shell Rotella Synthetic, but it's better than most OTS oils. That viscosity is for race motors tho.
Old Sep 9, 2008 | 12:24 AM
fastcrvi's Avatar
you will do just fine. i wouldn't run it during cold winter... although.. thicker oil = more fuel.. so you'll end up paying the difference in gas.. want fuel economy, run 5w30.
Old Sep 9, 2008 | 08:09 AM
mugenr#1011's Avatar
Default Re: 15w50 full synthetic (fastcrvi)
it will definatly affect fuel economy. just do what you can but since it is a new motor you have to be careful during the break in period
Old Sep 9, 2008 | 08:15 AM
thanks guys
Old Sep 9, 2008 | 10:54 AM
HSPxNick's Avatar
damn and this guy got an itr?
s2k5
Honda S2000
21
Sep 22, 2007 08:44 PM
J.nguyen
Honda S2000
16
May 19, 2007 09:02 AM
Hwj_33
Sep 1, 2006 09:32 AM
JaggedSpike
Apr 12, 2005 04:22 PM
quazar
11
Oct 23, 2004 05:50 AM
