Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 Accord - short O2 sensor problem
Old Sep 6, 2008 | 07:58 AM
alertik's Avatar
Default 03 Accord - short O2 sensor problem
hi all,
I have 03 arrord 4dr Lx 4 cyl, auto with 140k milies.
I shorted O2 sensor wires, while trying to remove exhaust cover which fell off while on the highway... engine was on.
now my check engine, battery and ABS lights are on. Cruise control doesn't work. car drove home (20 miles) ok.
i inspected sensor wired and they are not short anymore. i reset the ECU. problem is still there.
I'm wondering if O2 sensor shares the fuse with the other controls. but I'm not sure which fuse it would be -- visually everythin looks ok.
any ideas what i should do, before taking in to the dealer for $99 diagnostic...
thanks a lot!
Old Sep 6, 2008 | 11:10 AM
Ross 2.0's Avatar
In a Junkyard near you.
Check fuse 23 and fuse 4 in the under dash fuse box.
Old Sep 6, 2008 | 11:39 AM
alertik's Avatar
4 and 23 are good. I hope o2 sensor doesn't go directly into ECU? when i shorted wires -- it could of been any of the 4 with each other or with ground if it makes any difference.
thanks for you help.
Old Sep 6, 2008 | 01:53 PM
Ross 2.0's Avatar
Double check all the fuses in all 3 fuse boxes. You're sure to find a blown one.
MissingLugNut
Honda Accord 2016- 2017
Apr 15, 2018 05:33 AM
vrotsos991
Honda Civic (2001 - 2005)
Jan 23, 2017 12:45 PM
iKhmaiFoSho
Jan 6, 2006 01:56 PM
beaterdriver
Mar 4, 2005 12:36 PM
Spudddy
Aug 3, 2003 05:36 PM
