fuel injectors not firing
Old Sep 5, 2008 | 02:08 PM
hks_Racing's Avatar
Default fuel injectors not firing
im getting fuel and spark but for some reason im not getting gas past the injectors, im really lost i tried cleaning all the ground and the the thermostat ground, tried switching with a known working ecu and main relay, i even switch the engine harness and body harness. yes the motor works this is the third motor i tried and still nothing can someone help me out
Old Sep 6, 2008 | 01:09 PM
hks_Racing's Avatar
Default Re: fuel injectors not firing (hks_Racing)
nobody knows?
Old Sep 6, 2008 | 02:27 PM
Sr420Det's Avatar
Have you tried switching injectors?
Old Sep 7, 2008 | 02:30 AM
hks_Racing's Avatar
Default Re: (Sr420Det)
yep i tried tha too
Old Sep 7, 2008 | 07:08 AM
Mr Tickle's Avatar
I've just come across the same problem with my car and its hurting my head thinking about it.
Nothing is working!
Old Sep 7, 2008 | 07:12 AM
big-cat's Avatar
have you checked all your fuel lines and cleaned them out and the fuel filter? fuel rail? how much gas is in your tank?
Old Sep 7, 2008 | 08:35 AM
twinksack's Avatar
* B A N N E D *
Default Re: (big-cat)
did you check to see if your injector clips are getting a signal
Old Sep 7, 2008 | 09:40 AM
Mr Tickle's Avatar
Im getting fuel to the rail no problem but not coming past injectors. Half tank showing and a fuel filter replaced about 4 months ago.
Im going to try and test injector signal tomorrow.
Is it just a case of putting a multi-meter to the clips or is there a specific way to test as this is not something i've had to do before.
Any help would be great!
Old Sep 7, 2008 | 10:45 AM
big-cat's Avatar
sounds like it has something to do with your injector clips. you said you tried different injectors and still not all 4 would go bad at once. might have something to do with a fuse.
Old Sep 7, 2008 | 11:00 AM
Mr Tickle's Avatar
Just checked the clips for voltage. Getting 12v all across and it drops when cranking over.
I checked the fuses and took each one out and checked individually. None gone.
Old Sep 7, 2008 | 11:49 AM
big-cat's Avatar
how much battery life you have in it?
Old Sep 7, 2008 | 02:53 PM
Mr Tickle's Avatar
The battery was dead but connected to another car via jump leads and cranked over well.
Old Sep 8, 2008 | 08:35 AM
Mr Tickle's Avatar
Bump
Old Sep 8, 2008 | 08:40 AM
kbouchard1092's Avatar
Default Re: (Mr Tickle)
this happened to me before. i ran power across each injector individually to see if i heard a click. two of them did not click. i replaced the two and it started up instantly. if your getting power to the injectors at the harness and checked to see if they click when energized with 12volts across contacts. then i would think it may be ecu related since the ecu is what grounds out the injectors
Old Sep 8, 2008 | 09:14 AM
Mr Tickle's Avatar
Default Re: (kbouchard1092)
I checked the injectors and they all click when 12v is put through them.
Tried an ECU out of another car too and still nothing.
Old Sep 8, 2008 | 09:20 AM
i dont remeber what the ecu use to fire the injectors there has to be some kind of input. it maybe something in the distrubtor if i remeber right. if you have a spare distrubtor you may wana try to swap that out. but im not really sure about that tho
Old Sep 8, 2008 | 09:26 AM
Mr Tickle's Avatar
Tried a working dizzy too!
Going to go over it all again testing everything again and see if i have missed something.
I appreciate the help
Old Sep 8, 2008 | 09:31 AM
hks_Racing's Avatar
yeah im getting gas but im not getting any voltage from the injector clips but the thing is i replace the engine harness multiple times and the body harness
Old Sep 8, 2008 | 09:32 AM
did you ground the wires that attach to the thermostat housing.
Old Sep 8, 2008 | 09:44 AM
hks_Racing's Avatar
yup i did that and i cleaned it
Old Sep 11, 2008 | 09:08 AM
Mr Tickle's Avatar
I'm still having the same issue.
Taking the car over to a buddies in the next few days so ill let people know whats going on.
Old Sep 13, 2008 | 10:29 AM
Mr Tickle's Avatar
Found my problem - broken wire in the harness.
Joined it back up and fired straight away!
Old Apr 11, 2024 | 02:55 PM
Bseriesek2891's Avatar
where at in harness , where injector clips run or further in ?
90civSi
Jun 22, 2006 12:23 PM
Sinner
Jun 8, 2003 03:03 PM
Sinner
Jun 6, 2003 02:25 PM
iperez
Feb 19, 2003 09:05 AM
baonest
Aug 5, 2001 02:51 PM
