Eg Leaking...HELP A NOOB
Old Sep 5, 2008 | 08:09 AM
92fourdoor's Avatar
Default Eg Leaking...HELP A NOOB
Alrighty honda guys.. anyone ever hear of a civic leaking mass amounts of water onto the floor....
I just got a civic a couple months ago and i started noticing that when the sprinklers are on or it rains alot...my floor would be kind of damp...
well we had a lot of rain yesterday and i noticed my whole floor was soaked with water...usually it was just around the driver side that i actually noticed but when i actually took the time to check everything the entire floor under the seats and in the rear of the car were sopping wet?
my windshield seal is bad i think (the trim is falling off i need to replace that...but why would the rest of the car be wet as well??
Please help!!!!
Old Sep 5, 2008 | 08:23 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Eg Leaking...HELP A NOOB (92fourdoor)
There's a reported non-recall on firewall-to-chassis sealers on EGs. Also, if the doors sag at all, water gets in there as well. It's pretty common and it's unlikely you'll find an easy fix.
Old Sep 5, 2008 | 11:40 AM
92fourdoor's Avatar
hmmm ok...well that sounds reasonable to me...me and a buddy are tearing out the insides tomorrow...we'll see what we find i guess
Old Sep 5, 2008 | 11:49 AM
00eddie00(95eg)'s Avatar
Default Re: (92fourdoor)
never heard about this happening before hmmm check and replace all seals, also like the othe rguy mentioned check your doors you can do a smoke test to see if there properly sealed. also check the the under carrige of the car for rust and wear.....like i said i never heard of this happening good luck bro
Old Sep 5, 2008 | 12:42 PM
92fourdoor's Avatar
Alrighty thanks for the replies...whats the best way to do a smoke test??
Old Sep 5, 2008 | 02:23 PM
00eddie00(95eg4)'s Avatar
if you have access to a smoke machine use that and try to make the soke go thru were you think it might be leaking thru
Old Sep 5, 2008 | 03:08 PM
batallic's Avatar
Default Re: (00eddie00(95eg4))
i get the same problem but for my ej1
Old Sep 5, 2008 | 05:33 PM
jdmdc5abp's Avatar
Does you car have a sunroof if so it might be what happened to my 92 civic si there is a drain tube that is down under the dash in the "a" pillar area that can become disconected and when it rains or car wash my whole floor board got soaked it is an easy fix hope that might help
Old Sep 6, 2008 | 01:54 AM
92fourdoor's Avatar
No sunroof sorry...do you think it could still be the same thing though?? i know water has to run somewhere
92fourdoor's Avatar
Default Re: (batallic)
what did you do?
Old Sep 7, 2008 | 09:11 AM
jdmdc5abp's Avatar
mine had the drain tube for the sunroof of course that wont apply to you sounds like the windshield area is where I would look maybe under the wiper cowl. There is an opening there for air to come in
Old Sep 7, 2008 | 09:20 AM
jimmy o.'s Avatar
found this if it helps at all
There may be water leaking into the passenger footwell because of insufficient sealer on the seam at the firewall. Look for rust on the floor pan and run water over the right lower corner of the windshield to watch for water leaks before buying the car.
Old Sep 7, 2008 | 09:29 AM
IndySporty's Avatar
Default Re: (jimmy o.)
this is interesting because mine gets water in the passenger floorboard area and I can see a place on the door seal where the greatest curve is that is "dirty" as if water has been leaking by it, as opposed to the rest of the seal which is "clean" as if it has been sealing properly.
Old Sep 7, 2008 | 09:30 AM
93cxhatchsir2's Avatar
funny thing is i just went outide this morning and found the same thing:it appears as though water is coming in through the grommet in the firewall.my grommet is popped out since i ran some wires through it a couple of years ago,and ive only noticed recently that it was damp,today there was about a half-inch of water on my drivers side floor i will pop the grommet back in today and see if it helps anything.
Old Sep 7, 2008 | 05:44 PM
92fourdoor's Avatar
thanks guys...i to have ran wires through my firewall..but theres no way that much water can get through there...and all the way through the back of the car and on both sides (grommet on the passenger side)....i now have my entire interior ripped out minus my driver seat...and it is sitting in front of all the sprinklers i could find...soo we will find out in the morning where all the leaks are coming from...HOPEFULLY LOL....anyones windshield seal bad??
Old Sep 13, 2008 | 12:12 PM
yea my winsheild seal is also shot,sometimes i can push it in and it stays other times it is popped out,which would explain the sporatic leaking.did you find the leaks source yet?
eddieddie
Sep 2, 2013 07:36 PM
dannyly17
Oct 30, 2009 08:56 AM
smile_78905
Dec 6, 2008 06:34 PM
Ryan C
65
May 2, 2006 10:20 PM
gezer
14
May 21, 2003 08:22 AM
