My first engine swap, yes i am a newb....b18a1 into ek
Old Sep 4, 2008 | 05:57 PM
B18a1 97 Ek's Avatar
Default My first engine swap, yes i am a newb....b18a1 into ek
Hello, im michael and im 16.
This is my first swap, i bought my 97 honda civic ek, about a year ago.
And now im looking for more power so i found a 94 ls b18a1 cheap so i thought i would give a swap a try.
Im new to honda's so any help or tips on what to do and what not to do will help alot,
Thanks
this is the block.
Modified by B18a1 97 Ek at 9:00 PM 9/4/2008
Modified by B18a1 97 Ek at 10:36 AM 10/8/2008
Old Sep 4, 2008 | 06:12 PM
Default Re: My first engine swap, yes i am a newb....b18a1 into ek (B18a1 97 Ek)
Can someone please tell me how to post pictures up here? thanks alot if you can tell me how.
Old Sep 4, 2008 | 07:05 PM
twinksack's Avatar
* B A N N E D *
did you just buy the motor or a whole swap if you got the whole swap you wont want to use the yranny you need a hydro tranny it will make it much easier being its your first swap
Old Sep 4, 2008 | 07:15 PM
I bought a b18a1 block and head, that it so i have missing parts that i need to piece together. I have pic of what i got but i dont know how to put them up...
Old Sep 4, 2008 | 07:24 PM
LA_HONDAS's Avatar
Default Re: (B18a1 97 Ek)
you need a 92-01 hydro b-series tranny
99-00 civic si shift linkage and axles
and use your stock motor harness and you need motor mount kit for a b-series swap in a ek
Old Sep 4, 2008 | 07:28 PM
Thanks alot LA_HONDAS, this is one thing i have been trying to find out for a while!! Thanks alot!!!!
And i think this b18 is a 0bd1 do i need a jumper to 0bd2 right?
Old Sep 4, 2008 | 07:47 PM
LA_HONDAS's Avatar
obd1 is better but you dont need obd1 unless tuning it
just get a 96-98 ls ecu for now and save up for obd1 conversion and a good ems like hondata,ectune,neptune,ect with a p72,p28,p13,p06 ecu and you good to go
and you need to rewire iat sensor
Old Sep 4, 2008 | 08:03 PM
Ok, well i finaly got my pic's up... so tell me what you guys think. I was told this ls has about 100k on it, and for that matter do you think its in ok shape?...
Also the head gasket went out of it before i got it.. is that a big problem?
Old Sep 4, 2008 | 08:14 PM
LA_HONDAS's Avatar
have the head and block checked
and that white sensor on the intake is the iat sensor
Old Sep 4, 2008 | 08:19 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
extend the iat and iavc sensor. Also you need to add a crank fluctuation sensor at the crank. since your keeping it obd2 there are few stupid sensors you have to leave.
You need the mount that attaches from the driver side motor to the chassis mount
99-00 SI rear t mount
depending on what a/c compressor your running that will be diff.
teg front lower tranny mount
SI top tranny mount i believe
Bseires radiator hoses to make things easier
Old Sep 14, 2008 | 05:27 PM
so i need a b series hydro tranny right?
Old Sep 14, 2008 | 05:34 PM
LA_HONDAS's Avatar
yes you do
92-00 civics and 94-01 tegs are hydro
Old Sep 14, 2008 | 08:05 PM
Thanks, im going to buy a trans tomarrow.
Old Sep 14, 2008 | 08:09 PM
Getting there, getting head bolts tomarrow.. the heads just sitting on the block atm.lol
Old Sep 16, 2008 | 04:30 PM
I was checking out my head, and i found a broken bolt in the cam cap. So i think im going to get a new head, any suggestions on what kind i should get? B16? B18c or what u guys think.
Thanks
Old Sep 16, 2008 | 05:07 PM
LA_HONDAS's Avatar
ill sell you a b16 head comes with b16 cams, intake manifold, brand new dizzy obd2, brand new vtec solenoid everything you need you just have to buy gsr head studs ls head gasket 3/8" npt to -6an,1/8"npt to -6an fittings and 1/8" npt plug and -6an lines and end
the dizzy and vtec solenoid cost me $300+ and ill give you the fittings and hose ends just have to fined them
Old Sep 16, 2008 | 05:27 PM
how much?
Old Sep 16, 2008 | 05:38 PM
LA_HONDAS's Avatar
pm'ed
Old Sep 21, 2008 | 09:23 PM
The head all torqued down. Getting close
Old Sep 22, 2008 | 01:09 AM
143MYVTECEF's Avatar
first get the motor and the head hot tanked, then i would have a machine shop at least re-hone the cylinders and get new bearings becasue that block looks beat, and also have the head gone through. have them replace valve seals and if you can afford it have them reseat the valves too. This should all be pretty cheap and will save you time and money later.
Old Sep 22, 2008 | 05:42 AM
how much will that all cost?
Old Sep 22, 2008 | 06:58 AM
LA_HONDAS's Avatar
just save your money and build it
your looking at $400+ to do all that
Modified by LA_HONDAS at 8:13 AM 9/23/2008
Old Sep 23, 2008 | 04:34 AM
vertex's Avatar
You might as well replace the pistons and rods so you can add a turbo and save yourself the headache down the road. Do it right the first time since your car is currently running.
Old Oct 1, 2008 | 03:02 PM
spens 91 Ef's Avatar
when are you gonna get this done dude youve almost had this engine for a year and the only thing youve done is buy two heads for it and a gasket kit sell that b16 and the other head you need money you poor man
Old Oct 2, 2008 | 09:41 AM
Default Re: My first engine swap, yes i am a newb....b18a1 into ek (spens 91 Ef)
Going to clean the block and head up soon, and still looking for a hydro trans...
I didnt think they would be so hard to find..
