Why won't it start?
It's been a while since i've been in here .. andddd for those of you that remember, i'm still in that lawsuit (ugh) for that accident and i still don't have a bike
But, I'm here for a friend who is trying to get his bike started. and he isn't sure what else to do. here is the info on it ..
1972 Honda CB-350 FOUR
- Professional rebuilt/cleaned carbs
- New battery
- New spark plugs
- New fuel
- New oil
Checked spark plugs, they are all getting spark.
It turns over, but just won't start.
What would you guys suggest next?
- New battery
- New spark plugs
- New fuel
- New oil
Go down the check list of what a motorcycle needs to run.
Turn over
Compression
Fuel
Spark
If youre getting spark and its turning over, most likely somethings wrong with the fuel system.
Turn over
Compression
Fuel
Spark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx »</TD></TR><TR><TD CLASS="quote">what is the easiest way to check if it's getting fuel? </TD></TR></TABLE>
With your nose...
you should be able to smell gasoline, it may be faint but it'll be there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slm »</TD></TR><TR><TD CLASS="quote">Time to see if its getting fuel, as long as your fairly sure your sparks are in order.</TD></TR></TABLE>
Even if its not it would sputter and attempt to stay alive.
With your nose...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx »</TD></TR><TR><TD CLASS="quote">what is the easiest way to check if it's getting fuel? </TD></TR></TABLE>I would try to turn it over a few times, and check the carb bowls, should be a little screw at the bottom of the carbs. If there is fuel there, I would say you are getting fuel. You could also try sprayingh some started fluid in the intake.
I just talked to him. He said they tried the starter fluid earlier and nearly caught the apartment complex on fire. He also said they smell fuel.
They try and start it and it sputters and tries to stay alive, but it just won't go.
Any suggestions on what to look at?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx »</TD></TR><TR><TD CLASS="quote">He said they tried the starter fluid earlier and nearly caught the apartment complex on fire.</TD></TR></TABLE>
Meaning what? That's not an answer.
An engine only needs four things to run:
- spark
- fuel
- compression
- correct timing
Never assume that you have any of these. ALWAYS check them all, preferably in that order.
- spark
- fuel
- compression
- correct timing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx »</TD></TR><TR><TD CLASS="quote">Meaning that when they tried the starter fluid, it didn't start it up.</TD></TR></TABLE>
Provided that they knew what they were doing, this indicates that the problem does not lie with the fuel system.
Check compression and timing.
scotty.b16a1
Dec 31, 2012 01:54 PM
quad
20
Mar 14, 2007 05:16 AM
