D16Z6 coolant leak
Old Sep 4, 2008 | 01:43 PM
Outrun's Avatar
Default D16Z6 coolant leak
My car overheated to Vegas again. It overheated in June during a previous Vegas trip and I ended up replacing a bypass hose that had split and was spraying coolant all over the place. I thought my problem was solved but now I see coolant leaking in the front of the engine just behind the exhaust manifold maybe 3 inches or so below the exhaust ports. I tried looking over the Helms .pdf but that thing is kind hard to navigate without knowing the page numbers.
Old Sep 4, 2008 | 02:01 PM
94EG8's Avatar
Seagull Management
Default Re: D16Z6 coolant leak (Outrun)
Its leaking around the frost plug, see if its loose, if it is tighten it, might also be a good idea to replace the crush washer while your at it too, I've never seen a frost plug back out of a honda. I'd be concerned about that.
Old Sep 4, 2008 | 02:13 PM
Outrun's Avatar
Default Re: D16Z6 coolant leak (94EG8)
Thanks. I've been so tired from Vegas that I was too lazy to prop the car up to look at it. My friend found a diagram of it too.
Old Sep 4, 2008 | 05:45 PM
ieatpaint315's Avatar
part 17 and 29, why did you loosen the plug? there are fresh socket marks on it. buy part 29 and torque to spec.
MattsLegit
10
May 12, 2016 05:52 PM
EK45VTi
Nov 21, 2006 12:51 PM
vtecpoweredsol
May 19, 2005 11:20 PM
nikkon
Mar 22, 2005 10:08 AM
xavior66
11
Jan 21, 2004 01:27 PM
