95 ex idles high after cleaning intake manifold
Old Sep 4, 2008 | 01:42 PM
elmejor's Avatar
Default 95 ex idles high after cleaning intake manifold
i have a 95 ex with a gsr swap and yesterday i decided to clean the intake manifold with some carb cleaner, after cleaning it and putting everything back together my car is now idling at 4500 rpm, (i lost one of my injector rings but my car is not having a fuel leak, this wouldnt have to do nothing with it will it?)
Old Sep 4, 2008 | 07:08 PM
geebs's Avatar
Default Re: 95 ex idles high after cleaning intake manifold (elmejor)
you lost an injector o ring? dangerous...
did you remove the intake manifold from the head?
if so, did you use a new intake manifold gasket?
take some carb cleaner and spray around the intake manifold.. see if the idle changes any.. sounds like a major vacuum leak..
Old Sep 4, 2008 | 07:10 PM
slacks's Avatar
Default Re: 95 ex idles high after cleaning intake manifold (geebs)
did you tighten the manifold bolts in sequence to the head? i'd check there first.... and replace that injector o-ring pronto
Old Sep 5, 2008 | 06:29 AM
elmejor's Avatar
yes i replaced the manifold gasket, and yes i sprayed carb cleaner to the throttle body and it idles down and also to the intake manifold, (by the way i did this with the engine on is that the right way to do it?)
Lilsoldierbenny
Apr 16, 2010 07:27 AM
CountDracura
Mar 24, 2009 12:56 PM
jaydem7
10
Aug 11, 2007 08:41 AM
RACEPAK
Nov 11, 2004 08:38 AM
turboman
Apr 7, 2004 06:39 PM
