ex intake manifold question
i have a d16y7 engine all stock but with an ex or y8 intake manifold and throttle body. Will that intake manifold cause the CEL to come on? I have that intake manifold on it right now and my rpm fluctuates and sometimes die out. Could that be the reason why? Will this intake manifold cause other problems?? Thanks!!
are all of your hoses tight? your idle could be a small vacuum leak. check those. is your check engine light on? if so, get it checked and see why your car is throwing a code.
Re: (jaydem7)
what year is the manifold if its the later models then it probably has holes above the injectors to help with atomization and swirl of the Fuel/Air, also the Automatic Manifolds dont have IACVes
Re: (highrev1987)
the EX intake manifold has to be a 96 - 99 and its NOT an automatic. i have it on the car right now, but im not sure if i can pass smog with it. anyone have a d16y7 engine with a y8 intake manifold set up??
Re: ex intake manifold question (jaydem7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydem7 »</TD></TR><TR><TD CLASS="quote">i have a d16y7 engine all stock but with an ex or y8 intake manifold and throttle body. Will that intake manifold cause the CEL to come on? I have that intake manifold on it right now and my rpm fluctuates and sometimes die out.
<FONT COLOR="red">Could be your IACV or bubbles in the coolant.</FONT>
Could that be the reason why? Will this intake manifold cause other problems?? Thanks!!</TD></TR></TABLE>
redracer1024
11-11-2005 10:42 PM
ITLNstallion818
07-22-2004 05:35 PM
