Oil on spark plug threads, kinda diff. ? (searched)
Old Sep 4, 2008 | 09:54 AM
VTEC_Du_Ma_Mai's Avatar
Default Oil on spark plug threads, kinda diff. ? (searched)
I just replaced the head gasket and valve cover/spark plug gaskets yesterday. Now all 4 plugs have oil all over the threads.
Whats confusing me is that there is no oil on the top of the plug, none on the plug wires, and theres no oil around the spark plug grommets/gaskets, and none in the spark plug "cylinders". Also the compression test #'s are:
#1 228
#2 231
#3 236
#4 240
Is there anything else that could be causing this? Any input, comments, suggestions, or questions would be appreciated. Thanks
Old Sep 4, 2008 | 12:15 PM
Default Re: Oil on spark plug threads, kinda diff. ? (VTEC_Du_Ma_Mai)
help
Old Sep 4, 2008 | 08:36 PM
Turbo B18C EJ6's Avatar
The oil is proberly coming from the gaskets you just installed. maybe one fell out of place or something. pull the valve cover and recheck.
Old Sep 4, 2008 | 11:30 PM
Default Re: Oil on spark plug threads, kinda diff. ? (Turbo B18C EJ6)
yea ill prolly recheck everything. but just wondering, if the oil was coming from the spark plug tube seals, wouldnt there be oil in the plug cylinder or at least on the plug wires? thanks for the input.
Old Sep 5, 2008 | 07:45 AM
LastGenEK's Avatar
If there is just a little visual around the threads its fine, Mine does it pretty muck everytime i pull the plugs and its just a little bit
Until it starts to puddle dont worry
Old Sep 5, 2008 | 01:41 PM
Default Re: Oil on spark plug threads, kinda diff. ? (LastGenEK)
oh ok. but do you know where it could be coming from? its wierd since ill clean them off, drive ten mins, pull them right away and then theyll be wet with oil again. maybe im just being paranoid but if anyone knows the answer that would be cool. if not then i guess i wont worry too much about it. thanks for the response
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
HCJDM1
19
Dec 12, 2007 09:41 AM
B18CRacer
Jul 14, 2004 05:06 PM
gixxer6
Oct 29, 2002 01:10 PM
mailforjon
Aug 5, 2002 04:34 PM
