strut and sway bar help
Old Sep 4, 2008 | 09:35 AM
918eg's Avatar
Default strut and sway bar help
I'm buying a set of strut and sway for my EG and my question is
where about do i find the spot for sway bar both front and rear?
Old Sep 4, 2008 | 09:49 AM
obuhmyuh's Avatar
Default Re: strut and sway bar help (918eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 918eg &raquo;</TD></TR><TR><TD CLASS="quote">I'm buying a set of strut and sway for my EG and my question is
where about do i find the spot for sway bar both front and rear?</TD></TR></TABLE>
they connect to your lower control arms (LCA's), you're going to need LCA's that have holes for a sway bar to bolt up to though.
Old Sep 4, 2008 | 12:59 PM
rpared01's Avatar
should should be ok with the rear sway bar, Your rear stock LCA's should have the holes for the rear sway bar. for the front im not sure, but when i did mines to my ej6, i needed to change out the front LCA's and the forks.
Old Sep 4, 2008 | 02:05 PM
obuhmyuh's Avatar
Default Re: (rpared01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpared01 &raquo;</TD></TR><TR><TD CLASS="quote">should should be ok with the rear sway bar, Your rear stock LCA's should have the holes for the rear sway bar. for the front im not sure, but when i did mines to my ej6, i needed to change out the front LCA's and the forks.</TD></TR></TABLE>
you're wrong. stock eg rear LCA's do not have sway bar mounting holes. I'm unsure of the front because my del sol si came with a front sway bar (21mm)
andyvaj
Mar 18, 2005 09:51 PM
Ti3d in
Suspension & Brakes
17
Feb 8, 2005 07:37 AM
jtl
Apr 1, 2004 04:24 PM
p1driftfiend
14
Feb 23, 2004 12:18 PM
Dorikamu
Oct 25, 2002 01:01 PM
