read if you know about stuff
Old Sep 3, 2008 | 04:49 PM
thebleek's Avatar
Default read if you know about stuff
okay, here is my issue
i have a 00 y8 motor, it was swapped into my dx hatch.
the head had some crazy tapping issues so i swapped a y7 onto it. with a y8 manifold that was previously on my d16y7 motor. so it wont have any problems. except on the back there are 2 holes with 2 bolts it plugged it because i believe the y8 manifold i had was from a manual and not an auto. because the auto has them blocked off.
here is the problem. when i run the y8 ecu it will start the car but it idles all [freak]ed up...
when i swapped the y7 in there, without doing the iacv fix it wont start. it sounds like it wants to but wont. then i get an error code 14 [ics malfuntction??]
also when i had the y7 head on the y8 block still running the vtec cpu it would idle all [freak]ed up and be around like 100rpms lol.
all i did was change the oil, headgasket, and coolant. I dont understand what is going on. Can anyone help me? i had an old thread but i felt i needed to update, because its no longer how it was.
for reference here
https://honda-tech.com/zerothread?id=2378874 is the old thread. im about to kill myself here.
Old Sep 3, 2008 | 05:19 PM
thebleek's Avatar
HELP
Old Sep 3, 2008 | 05:26 PM
skate_volcom2006's Avatar
Is your car a manual?
Are you using a y8 manual ECU?
An auto y8 motor uses a 3 wire IACV that is mounted to the throttle body and a Y8 manual uses a 2 wire IACV which is located on the back of the manifold. Sounds like you have them mixed up.
Old Sep 3, 2008 | 05:31 PM
thebleek's Avatar
Default Re: (skate_volcom2006)
my car is a manual
im using the manual ecu
i dont have them mixed up...i put the y8 intake manifold on the Y7
just think of my motor being a y7 and thatll clear up any confusion
PardonmyEK9
May 28, 2010 09:12 AM
SilverDEj6
Jan 30, 2009 03:56 PM
thebleek
Sep 5, 2008 10:10 AM
SOHC_civic_si
May 4, 2008 08:50 PM
TheAutoboxer
Apr 26, 2003 03:21 PM
