brake master cylinders & brake boosters interchangeable?
Old Sep 3, 2008 | 03:16 PM
aznlaoboi315's Avatar
Default brake master cylinders & brake boosters interchangeable?
I have 94' GSR and I need a new brake master cylinder, will the one I have from my 99'GSR Shell work with the 94" Booster? The reason I ask is because I noticed 94-97 Integras use a different type of ABS brake setup then the 98-01's so i want to make sure it works. Thanks alot.
Old Sep 3, 2008 | 03:36 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: brake master cylinders & brake boosters interchangeable? (aznlaoboi315)
It won't work with your 94-97 brake lines.
Old Sep 3, 2008 | 04:03 PM
Default Re: brake master cylinders & brake boosters interchangeable? (Dogginator)
Thanks for the reply. I was thinking about ditching the ABS anyways. So would it work if I used the 99' GSR Master Cylinder and purchased all new OEM front brake lines from a 98' RS and use the 98' RS proportioning valve??
KBG Indey
Nov 20, 2006 12:50 PM
VTECth1s
Jun 9, 2006 06:21 PM
lollypopking
Jan 16, 2005 09:51 PM
JRSC EM1
12
Nov 8, 2003 10:41 PM
