Help with unknown sensor
Old Sep 3, 2008 | 05:05 AM
garyc17's Avatar
Default Help with unknown sensor
Need help with a broken wire in my engine bay. It leads to a connector which plugs into the thermostat housing where the top radiator hose fits into. There are 2 wires to this plug. The black one seems to be connected but doesn't seem firm. The green one is totally disconected from the plug. What does this plug connect to? Is it the water temperature sensor? I checked and my water temp gauge is working. The fan comes on too at a certain temperature. Just worried it might be something critical. To add, my thermostat has always been removed.
Can I get this plug from a honda dealer? It seems to be part of the engine wire harness. Any help appreciated.
Old Sep 3, 2008 | 05:19 AM
R.Kelley's Avatar
Default Re: Help with unknown sensor (garyc17)
wow my reading skills suck
Modified by R.Kelley at 9:30 AM 9/3/2008
Old Sep 3, 2008 | 05:24 AM
R.Kelley's Avatar
Default Re: Help with unknown sensor (R.Kelley)
edit...i just noticed that you said that your not running a T-stat...you should put one in
Old Sep 3, 2008 | 05:39 AM
coolhandluke's Avatar
Gary, a picture is worth a thousand words. Take or find a picture here in this forum. Circle the senors/locations in question so we are all clear on the issue.
Old Sep 3, 2008 | 06:23 AM
R.Kelley's Avatar
Default Re: Help with unknown sensor (coolhandluke)
i know there is three temp sensors...two in the head and the one your talking about on the t stat housing. i think the one your talking about is for the fans...but I could be wrong
Old Sep 3, 2008 | 02:35 PM
mstewar's Avatar
that is the rad fan switch.. surprised your fan is kicking on unless its coming on with the a/c or something..
Old Sep 6, 2008 | 07:43 PM
garyc17's Avatar
Yes, its the sensor at the T-stat. Could it be that I have a standalone ECU(PowerFC) which uses another method of turning on the fan and not via this sensor?
jetspeedz
Apr 5, 2018 07:53 AM
raider1qaz
Feb 13, 2013 12:14 PM
lorenzookc
Jan 26, 2010 06:22 PM
garyc17
Sep 6, 2008 08:30 PM
MOVE OVER
19
Dec 17, 2005 11:48 PM
