Anyone running the Treadstone kit?
Old Sep 2, 2008 | 11:39 PM
Barry White Wagon's Avatar
Default Anyone running the Treadstone kit?
Is anyone running the Treadstone turbo kit on their car?
http://www.treadstoneperforman...2FH23
How was the spool on the t3/t4 as a daily driver? Did you ever have any problems with that manifold? Can you give any views or impressions?
Old Sep 3, 2008 | 01:40 AM
jwicecold's Avatar
Some things are just worth trying.... maybe see what Google or Wikipedia has to say about it.
Old Sep 3, 2008 | 05:50 AM
accord2nrz's Avatar
Default Re:
I have treadstone components on my setup not all treadstone kit, but I am satisfied with their manifold and FMIC.
Old Sep 3, 2008 | 02:23 PM
Default Re: Re: (accord2nrz)
Cool, thanks for the replies guys. I did a little bit of searching and found out a little more, seems to be good pieces at a great price. The only thing that I'm questioning is the manifold.
It appears that the wastegate port is only on one runner, or is it two? I can't really tell by the picture. I'd like one where all four cylinders have access to the wastegate, I guess I can replace this piece and use the rest of the kit?
Old Sep 4, 2008 | 04:16 PM
accord2nrz's Avatar
Default Re: Re: (Barry White Wagon)
runner 1 and 2 feed into it. It is possible to keep the ac and ps with the setup. ( I did it) but unless the exhaust is run right you will run into problems with burning up alternators. Trust me. I did it. But I am more than happy with the mani.
I spool at 2500.
Old Sep 5, 2008 | 01:32 PM
Brad_and_the_acc's Avatar
Default Re: Anyone running the Treadstone kit? (Barry White Wagon)
I am running the Turbonetics Kit, and I like it. The only problem I had was the Mf2 secondary injectors that came with the setup. I would suggest getting a S300, VAFC or something. And that is not all you will need bigger injectors and so to fully utilize that setup. The manifold is a little weird, on the wastegate turbonetics says not to use a gasket but i have found that you have to use a gasket there. But it is a good starter setup. The A/C line will be right over the turbo (touching) and it will melt. You will have to have a custom A/C setup to keep it. You would also be able to bend that line a tad.
Modified by Brad_and_the_acc at 8:08 AM 9/6/2008
Old Dec 2, 2009 | 06:34 AM
S2Carbonworks's Avatar
Is there not anyone that makes a top mount kit or side mount kit for the accords?
Old Dec 2, 2009 | 07:18 AM
accord2nrz's Avatar
noperz. not to my knowledge
Old Dec 2, 2009 | 05:34 PM
H22_aCCoRd_07's Avatar
I ran the manifold in my old f22 turbo setup and it was just fine for me, i kept ps and ac!
Old Dec 2, 2009 | 07:18 PM
disertwi's Avatar
New User
I accept with information:The manifold is a little weird, on the wastegate turbonetics says not to use a gasket but i have found that you have to use a gasket there. But it is a good starter setup. The A/C line will be right over the turbo (touching) and it will melt.
Old Dec 2, 2009 | 07:20 PM
accord2nrz's Avatar
Yea you'll have to wrap it in heat wrap and bend it just a tad. You'll be alright after that.
Old Dec 2, 2009 | 08:25 PM
Also depending on the wastegate you use it might hit your hood... mine did
Old Dec 2, 2009 | 08:36 PM
accord_raffi's Avatar
The lines are maleable. You can bend them out of the way slightly without any issues. I don't like that manifold but for the price of the kit you can't really complain. My kit is up for sale if the car doesn't sell as a whole this weekend, but you'd have to lose a/c to use it. The good news is that it would come with a tune, downpipe, dumptube, oil pan tapped for the return line, and corresponding fueling options other than the walbro fuel pump.
Old Jan 29, 2010 | 08:38 AM
housefull's Avatar
New User
That's a very interesting topic. But this field is still new to me. It will be grateful if you give me some
more information about it. Thanks in advance.
__________________
Watch Edge Of Darkness Online Free
LSTEG98
Northeast (Sales)
Jan 16, 2012 04:11 PM
Barry White Wagon
Sep 4, 2008 03:37 PM
xQwertyx
Mar 28, 2006 09:35 AM
1badda
Dec 16, 2004 12:38 AM
BlownEJ6
Aug 24, 2003 07:04 PM
